Progress on the 57
Progress on the 57 Empty Progress on the 57
Post  512Fairlane March 25th 2012, 11:05 pm
Made some progress on the wife's 57 today. Pulled the 5.0 out of the donor car Mustang and set it in place in the 57. Fits great. This was too easy. I'm not used to bolt in style projects. We usually have to fabricate everything. We'll pull it back out to detail everything but the mock up looks like it will work.
http://www.flickr.com/photos/512fairlane/sets/72157629303741382/
512Fairlane
512Fairlane
Progress on the 57 Empty Re: Progress on the 57
Post  Mike R March 26th 2012, 12:28 am
looks like it was meant to be there
Post  56Tbird March 26th 2012, 8:51 am
The Ole 57 just swallowed that 5.0 .. Very Happy That'll make a killer driver!!
56Tbird
56Tbird
Post  bigblok2000ranger March 26th 2012, 10:14 am
Looks very nice! Are you planning on using the cars computer harness or buying aftermarket? A friend and I swapped a compete mustang FI harness into a Ranger about 10 years ago came out very nice and everything on the Ranger worked just as if it had come factory with a 5.0. We even put the V8 factory tach in the Ranger.
bigblok2000ranger
bigblok2000ranger
Progress on the 57 Empty Computer
Post  512Fairlane March 26th 2012, 10:22 pm
Yep. I kept the entire engine harness and computer. I started taking the rest of the under dash wiring out but after a few hours of unplugging those darn connectors I decided I didn't need all of that. I thought about using the gage cluster but decided it wouldn't look right in the 57 dash. I got the fuel pump inertia switch and relay etc. I need a good source for an external fuel pump because I have a brand new tank for the 57. I'm going to take my trick flow intake and GT-40P heads off my 95 Mustang daily driver before I sell it so this thing should run pretty good. Not quite a big block but a much easier swap and I can get close to 20 mpg.
512Fairlane
512Fairlane
Post  bigblok2000ranger March 26th 2012, 10:26 pm
You could probably add the in tank pump to the existing pickup assembly, I have done it before.
bigblok2000ranger
bigblok2000ranger
