c-6 no first gear
Gregaust
Notch 501
c-6 no first gear Empty c-6 no first gear
Post  Notch 501 September 23rd 2009, 1:53 am
got my tranny rebuilt last week by a local guy.....transgo kit few other internals......installed it went threw the gears no ist gear.......tranny guy came over tonight pressure was 220 in all gears but 1st it was 350.....took the valve body with him so we will see whats up tomorow...strange the pressure was that high
Notch 501
Notch 501
c-6 no first gear Empty Re: c-6 no first gear
Post  Gregaust September 24th 2009, 12:51 am
Yes i agree, should not of been that high. If was a transgo kit with modulator connected pressure should be around 130-150 and with low vacuum under load may go 180-200 max.
Gregaust
Post  Frank Merkl September 24th 2009, 1:48 am
He f'ed up on the VB
Post  Notch 501 September 24th 2009, 5:54 pm
hopefully he fixs his screw up.......
Notch 501
Notch 501
Post  Notch 501 September 25th 2009, 1:46 am
well the tranny guy came back tonight with my valve body and installed it. Have all gears with 220# on his gauge.....off to the track tomorrow night maybe i can make a pass after 9 when things settle down .......wish me luck... hopeing for mid 10s.....probably high 11s cold track
Last edited by Notch 501 on September 25th 2009, 1:48 am; edited 1 time in total (Reason for editing : spelling errors)
Notch 501
Notch 501
Post  Greg_P September 25th 2009, 10:57 am
That 220 seems awful high on the line pressure. It is very easy to reduce that pressure by shortening the spring on the main regulator a little, or simply using a different spring.
Greg
Greg_P
Greg_P
Post  Notch 501 September 25th 2009, 4:52 pm
ill relay that message to him and see what he says......what could be the outcome of too high of pressure......ill post what he said when i ask him about it to night leaving for the track right now to move staging around a bit expecting a huge car count....bracket stuff is done if they have lights they can run sticker cars.... No
Notch 501
Notch 501
Post  Notch 501 September 26th 2009, 5:23 am
did 2 shake down passes.......taking it easy..... 3rd pass left off idle went threw gears evertything fine.....4th pass left farely hard threw 1st and 2nd about 5000 rpm tranny let go..bounced off the rev limiter coasted around the corner at top end no forward gears...just reverse......well we will see if the tranny guy stands behind his work
Notch 501
Notch 501
Post  billandlori September 26th 2009, 9:43 am
Man, that sucks. What did it run?
Sounds like its time to get Mr. Merkl to build you up a trans.
Bill
Post  Greg_P September 26th 2009, 11:41 am
I have my spare trans for sale, it's a Broader Performance fully rollerized/manual VB 1000 HP wide ratio C6. It is being freshened right now, but when it's done it's got to find a new home,
Let me know if you could use it.....
Greg
Greg_P
Greg_P
Post  Notch 501 September 26th 2009, 12:20 pm
i would take your tranny in a heartbeat but the shipping would probaby be twice as much as you want for it... i really appreciate the offer....im going to give the tranny guy a chance he is respected with car guys here . i work at the local track here and im sure he doesnt want the back lash of people asking why he didnt fix my tranny......it was cool had 25 guys pushing the car on the trailer....didnt have to winch it on good bunch of guys.....
Notch 501
Notch 501
Post  Notch 501 September 29th 2009, 9:06 pm
tranny guy told me the front drum is cracked.....oh well .....for a slow street car i seem to be having a few problems ....street car shoot out this weekend i think ill enter .....need the seat time....
Notch 501
Notch 501
Post  Gregaust September 30th 2009, 12:11 am
Notch 501 wrote:tranny guy told me the front drum is cracked.....oh well .....for a slow street car i seem to be having a few problems ....street car shoot out this weekend i think ill enter .....need the seat time....
If it is cracked around the snap ring groove?? Look to lowering line pressure while it is apart.
Gregaust
Post  Notch 501 October 1st 2009, 1:55 am
on the edge of the drum its all cracked off like the edge of a bowl the lip is gone and ground down Ill try to put some pics up for you guys tommorrow.....ran out of time tonight ....just have one header and fill with trans oil.....going racing on friday if it doesnt snow....
Notch 501
Notch 501
c-6 no first gear Empty RE: Forward clutch drum cracking.
Post  saraco November 7th 2009, 7:14 am
Yeah, C6's have a tendency to crack the forward clutch drum right on the back edge happened to me twice. Getting a 4140 steel one from TCS products, that should fix it! Bit pricey BUT!! Especially getting sent down under!! Shocked
saraco
