Kaase oil pump with stud girdle
Kaase oil pump with stud girdle Empty Kaase oil pump with stud girdle
Post  cooter April 8th 2012, 12:16 am
is anyone running a kaase oil pump with main stud girdle? I tried to mock mine up and the pump rests on the main stud bolt. I have a canton girdle.
cooter
Kaase oil pump with stud girdle Empty Re: Kaase oil pump with stud girdle
Post  dfree383 April 8th 2012, 12:19 am
Ditch the girdle........ if your paranoid about it use cap straps.
Post  cooter April 8th 2012, 12:22 am
but the girdle makes it easy to mount my windage tray Laughing
cooter
Post  c.evans April 8th 2012, 12:27 am
Okay, if the girdle makes it easy to mount your windage tray and you want to keep it, then cut off that part of the girdle that is around the oil pump. I seen a thousand small block Ford girdles that are made that way. Only one side of the girdle goes up to the # 1 main cap.
Hope this helps,
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  dfree383 April 8th 2012, 12:28 am
Yep..... thats about all its good for.... Razz
Post  cooter April 8th 2012, 1:12 am
thanx, i will just cut it, i would rather keep the kaase pump than the girdle but now i have line honed with the girdle and i have bought and paid for the girdle so i may as well use it.
cooter
