Radial hype in index racing ????
building an engine to go 10.00 index racing at englishtown , and atco
this class seems to be competitve but have these guys are on radials
i would just think you would wont 28x10.5s or 29.5x10.5 ect for being consistent
Any input why the radials are being ran in this class ?
5pointslow- Posts : 1408
Re: Radial hype in index racing ????
on a good track a radial will be faster and they drive better than a slick. They are a different animal to work with and dont recover as quick as a slick if your going to have traction issues. Hit them "Hard" works alot a guys going fast doing it.
nitro717- Posts : 92
what would ya ue 275 or 28x10.5
yellowhorse7- Posts : 1382
trying to hook using strange 10ways and qa1 coilovers up front with a 1.76 glide motor should make close to 700 hp to run 9.90s for 10.00 index
have baseline upper suspension and anti roll bar stock location spriongs but small diam wolfe craft setup that are adjustable
i have no idea were to start
That single adjustable is going to give you headaches. Doubles are preferred because with a radial, you need to be able to tighten compression and loosen extension. They will need a lot of wheel speed and they need to be hit hard! Keep the power in it from the hit. 17-20 lbs psi Is a good place. Not knowing anything else about the car, this is all I can offer now.
thanks for info , maybe i will put a 28x10.5 on a 10 or 12 inch rim
the stuff i have is brand new and didnt realy want to change the stuff i had , i figd it be not ideal for the radial and being a new car/ combo and not being familiar with setup and tuning for a radial it prob will be very frustating
and im traveling 200 miles each way to the track .....id rather be consistanbt i think on the slicks and a tick slower than get there its hot and i smoke em everytime ....
but its so tempting to try the new m/t radial tho
5pointslow wrote:and im traveling 200 miles each way to the track .....id rather be consistanbt i think on the slicks and a tick slower than get there its hot and i smoke em everytime ....
Given the proper setup a radial will be faster 100% of the time. Less drag due to less tire "movement" = more efficient. And easier to drive to boot
i just dont think i have an ideal setup ... i have nice upper baseline setup thats the relocation kit ..like team z setup ,
qa1 coilover up front , i have travel limiters ..... but probem is cars mini tubbed with smal dia coil springs in stock location can adjust ride height , but have strange 10 ways .............
i can crank on those all the way so there tight , but i have no idea how to set the front end up , i just think to do it over coil overs in rear with double adjusters would be best
5pointslow wrote:i just dont think i have an ideal setup ... i have nice upper baseline setup thats the relocation kit ..like team z setup ,
No worries. I run a slick as well. Sometimes the headache of this small tire stuff gets old, lol
» index racing heads up ture question on size and gearing
» Declared Index Racing @ US60 Hardinsburg Kentucky in 2011
» cant get any damn info , ive put on yellow bullet ect ... the diff between a drag radial,radial slick,bias slick pros and cons
» Your feelings about all the hype
» Congrats Keith Fulp
