Leaky wheel question
My old school Center Lines are leaking out of the lug nut holes. They are 2 piece wheels with a bead of goo around the parting line. What would y'all recommend to reseal 'em up? I had a buddy buff 'em out too. They used to be satin.
cletus66- Posts : 865
Re: Leaky wheel question
Clean all the old goo out of the crack and take some GE clear silocone in the tube the one you use around shower doors in the bathroom and put in a caulking gun and force it into the crack where the wheels go together on the inside.Then come back with your fingure and whip the excess off and smoothing it out.We did that on one on a guy at work wheel back years ago and worked good and the wheel balanced out good.Just make sure you don't leave a lot of gloobs in the wheel or it might not balance out right.
Thanks, I'll try that .
damn that looks like a whole new car .....wheels look great
Louking Goood
Sorry Jeff no advice on this end
Dang Jeff ,that Cat sure put some shine on dem dere wheels!!! They look awesome!!
56Tbird- BBF CONTRIBUTOR
Thanks guys. Before he started polishing, the wheels appeared to be the same color as my concrete floor.
richter69 wrote:TA31
I googled that and came up with rifle scopes. I don't want to shoot it.
Edit: OK, I found it. Made by Motorcraft.
when I had my rims powercoated I had to replace the sealant around the middle of the rim. they are fine now.
Larry Williams- Posts : 884
» Leaky valve covers
» degree wheel question
» 69-70 Galaxie wheel question
» Need a wheel
» Wheel Tech Question / 92-96 F250 alcoa factory wheels
» Need a wheel
