A460 Exhaust port spacing
Barney
56Tbird
A460 Exhaust port spacing Empty A460 Exhaust port spacing
Post  56Tbird April 19th 2012, 3:35 pm
I made my zoomies off my A460 Ford Motorsport heads....Well...today i was trying to bolt them up to the TFS A460 heads on the engine in my car...And guess what?? The TFS heads from end bolt to end bolt are 1/8" narrower than the Ford Motorsports. You probably wouldn't notice it on a set of headers with slip in tubes,but I welded straps on these zoomies for support. I'm wondering if it would be better to cut them apart and reweld the straps or to ream the flanges out?? This stuff is really fun!!! Been remounting everything to get this engine in .. scratch
56Tbird
56Tbird
A460 Exhaust port spacing Empty Re: A460 Exhaust port spacing
Post  Barney April 19th 2012, 3:43 pm
Reaming the flanges out would probly be easier as long as the port alignment is good, and you have enough flange.
Barney
Barney
Post  c.evans April 19th 2012, 4:31 pm
You should have called Uncle Charlie, because you haven't been paying attention Exclamation Anyway, I've posted it a dozen times if I've posted it once,,,,,, but the old Ford Motorsports A-460 heads and the old TFS A-460 heads with the "block" cast lettering,,, had the Chevy bolt pattern on Ford bore centers of 4.900".
The current TFS A-460 heads, with the ends milled flat and smooth, with engraved lettering, have the Chevy exhaust bolt pattern AND is on Chevy bore centers of 4.840". Therefore, it can take a one piece Chevy header gasket. That's your difference and is the cause of your problem.
Charlie Evans
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  Lem Evans April 19th 2012, 4:45 pm
xxxxxxxx
Post  56Tbird April 19th 2012, 5:30 pm
I'm glad to know the difference now..It ain't no big deal either way. May just ream the flanges, I've got Jon Thee flanges and have plenty of room on them ,it won't take much to clear them . I can move them over enough with a screwdriver to line them ,but don't like that much pressure on the bolts being that they are in aluminum.. Wink
56Tbird
56Tbird
Post  69F100 April 19th 2012, 8:13 pm
56Tbird wrote:I'm glad to know the difference now..It ain't no big deal either way. May just ream the flanges, I've got Jon Thee flanges and have plenty of room on them ,it won't take much to clear them . I can move them over enough with a screwdriver to line them ,but don't like that much pressure on the bolts being that they are in aluminum.. Wink
Dan I would rem the holes alittle it might be tuff the 1st time but after you heat them up a few times they should not have that much pressure on the bolts as the heat will let the metal expand alittle.I had the same thing happen on the header I put on my 69 F100 after I had to make some mods to them after they was run awhile I don't have to pry on them to get them on.
Post  Barney April 19th 2012, 8:36 pm
You give me 2 minutes alone with it, and it'll fit Wink
Barney
Barney
Post  56Tbird April 19th 2012, 8:47 pm
Barney wrote:You give me 2 minutes alone with it, and it'll fit Wink
Come on down Killa!!! Laughing
56Tbird
56Tbird
Post  56Tbird April 19th 2012, 8:48 pm
I think I'd rather just go ahead and ream them to fit these heads too. That way if I have to put the other engine in ,they'll fit Exclamation
56Tbird
56Tbird
Post  c.evans April 19th 2012, 9:40 pm
Dan,
I try to use header studs and then serrated flange nuts on my stuff. That way you don't have to worry about crossthreading a bolt. I think I have a case of those header studs on the shelf and they are grade 8 with the small internal hex head. Switched to studs when I got tired of heli-coiling the header bolt holes in the heads.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  bbf-falcon April 20th 2012, 3:46 pm
Barney wrote:You give me 2 minutes alone with it, and i'll fix it Wink
Thats what SHE said Embarassed Razz
Dan,I also like the stud deal on mine.And it also makes the headers alot easier to install. If you need a new set of studs let me know and I will send you some. Of course you know mine will be VERY expensive to YOU. Laughing
Post  Lem Evans April 20th 2012, 4:34 pm
3/8" set screws made nice cheap studs.
Post  Barney April 20th 2012, 4:41 pm
A little lube and sweet talkin.
Barney
Barney
Post  56Tbird April 20th 2012, 5:24 pm
Barney ,it took a little longer than 2 minutes for me.....I guess I'm just slow scratch Maybe that's why I missed Professor Charlie's class on the Aheads too lol! Send them studs my way Rickie!! cheers
56Tbird
56Tbird
Post  bbf-falcon April 20th 2012, 6:03 pm
Ah ight Wink The ones w/insert for allen wrench coming your way. What length do ya prefer sir Question
Post  56Tbird April 20th 2012, 6:10 pm
How long's yours Rick?? I don't want for mine to be shorter than yours Razz But , I'm not sure I have room down there to clear the ones like Harold"s Laughing
56Tbird
56Tbird
Post  Larry Williams April 20th 2012, 6:54 pm
you guys getting out the ruler again? lol no measuring in cm's
Larry Williams
Larry Williams
Post  56Tbird April 20th 2012, 7:22 pm
Easy now!! Laughing
56Tbird
56Tbird
Post  342g April 20th 2012, 8:01 pm
[quote="56Tbird"]How long's yours Rick?? I don't want for mine to be shorter than yours Razz But , I'm not sure I have room down there to clear the ones like Harold"s Laughing [/quot
I resemble that remark, if you would have stayed awake, we wouldn't be having this discussion. Very Happy cheers
342g
342g
Post  bbf-falcon April 20th 2012, 11:36 pm
HE WERE DRUNK HAROLD,HE WERE DRUNK. DAVE D.Embarassed Evil or Very Mad Twisted Evil drunken drunken
Post  DanH April 21st 2012, 12:16 pm
header tubes are larger than exhaust port ,, no big deal . now if sloting the bolt holes moves the tube to cover the exhaust port .. then
DanH
