cam degree
cam degree Empty cam degree
Post  cturk1010 April 19th 2012, 10:25 pm
if you do a mild cam in a stock 429 would you have to degree the cam i have never done this always by and bolt you know i am putting a 554/575 cam in my 429 with dove heads and wonder if i needed to do this if so i will have to learn how as i am doing it myself thanks in advance for any advice
cturk1010
cam degree Empty Re: cam degree
Post  IDT-572 April 19th 2012, 10:29 pm
I degree every cam I install I have found to many that were not right.
Post  cooter April 20th 2012, 12:09 am
its amazing how many degrees the cam is out when you check it, i have however found the comp cams chain sets to be generally closer but i also degree everything
cooter
Post  rmcomprandy April 20th 2012, 10:22 am
Just put it in and you MAY get it close to right ... SOMETIMES. scratch
