where can you get a new c6 pump and sunshell washer
Looking at the thread below on the bushing install that looks like a new pump body if so where did you get it .While on c6s what about the steel #6 thrust washer on the sunshell ? One of mine is kinda warped from dragstrip abuse .Doug
manofmerc- BBF CONTRIBUTOR
Re: where can you get a new c6 pump and sunshell washer
I just bought some C6 transmission parts from https://www.wittrans.com/ quick service and a good selection of new and used parts. Takes a little time to learn how to get around their web site. Hope this helps you.
Louis
Louis
54BigB- Posts : 3
I think you're pretty limited to good used parts . Not seen "NEW" of either . If that washer on the sunshell is damaged might be time for roller bearings
Gregaust- Posts : 625
Greg I do have a roller bearing on the planetary set .Probably from all the years of abuse my sunshell bearing I will call it isnt flat .I have seen a new c6 pump body but it has been a while .And I will look at that website thanks a million Doug
Thank you big B
I pulled that what ever it takes website up big B man it is a good one !! And they have the sunshell race I need .Thanks for that Doug
» Ok to use plastic c6 pump thrust washer?
» Need a 2 piece fuel pump eccentric and cam bolt/washer for 351W.
» 3/8 ARP 200,000 psi cam bolt and thin hard washer ,is the washer to thin
» If it was easy, everyone would do it...
» ARP Washer?
» ARP Washer?
