Ok to use plastic c6 pump thrust washer?
Ok to use plastic c6 pump thrust washer? Empty Ok to use plastic c6 pump thrust washer?
Post  rocketpony August 7th 2015, 7:51 am
So in order to get correct end play I needed to use an old plastic thrust washer for the pump in my c6.
Is it ok to run these plastic washers? My tranny had a nice metal clevite one
rocketpony
Ok to use plastic c6 pump thrust washer? Empty Re: Ok to use plastic c6 pump thrust washer?
Post  supervel45 August 7th 2015, 9:34 am
All the stock one's I have taken apart seemed to hold up fine. I do prefer the metal ones though. Is this going behind a real high HP build or something mild?
Post  rocketpony August 7th 2015, 10:57 am
Behind a 1000hp 600ci
rocketpony
Post  Frank Merkl August 7th 2015, 12:43 pm
you can use either style
Post  rocketpony August 7th 2015, 1:51 pm
rocketpony
Post  Gregaust August 8th 2015, 4:21 am
Pretty rare to see a plastic one fail or with much wear . Use it and go Smile
Gregaust
