Which gear to run in 1/8th mile 5.13 or 5.29
+8
342g
61coon
wild pony
Copperhead
whitefield
12 posters
Page 3 of 3 Previous  1, 2, 3
Which gear to run in 1/8th mile 5.13 or 5.29 - Page 3 Empty Re: Which gear to run in 1/8th mile 5.13 or 5.29
Post  whitefield May 8th 2012, 11:10 am
dfree383 wrote:
whitefield wrote:
dfree383 wrote:
wild pony wrote:So now we have the right cam specs, what gear do you guys reccommend , or converter.
Its better, what he has should work. Something else is going on. Tune? Lack of Fuel? Cam degreed wrong? No cylinder Pressure? Only getting Half Throttle?
By the Wallace Calculator this things only making around 425-435hp...... Its a Lame duck IMO
Dave what do you speculate this engine should be making ?
an old 466 I had with blended Iron CJ, similar cam, intake and carb, but more compression was making north of 600 at the flywheel. I'd think this 429 should at least do 525-550 ish. I'd think that thing should be running 6.7-6.9's in the 1/8 mile with out issue.
The times are where his son and myself thought it should be 7.00 to 6.90. All he is asking to get out of it are some 7.20's or 7.teens. Weight of car I cannot say for sure only what he as told me . The car has been overbuilt in my opinion so he may be close on weight !
But again..... Same as with the cam... Whats it actually weigh.
whitefield
whitefield
Post  cool40 May 8th 2012, 8:50 pm
the gear is fine,if the sob will go 42-4500 on the t/b it should at least 60' half assed,even at 3800#.if it aint maken rpm very fast it's in the timing,ignition or cam.if it had fuel issues it probly would'nt rpm that high.too many things it could be but i'd say its a few things all together.ign timing too low and no advance or even a vac advance on a live vac port. study
Post  whitefield May 8th 2012, 11:00 pm
cool40 wrote:the gear is fine,if the sob will go 42-4500 on the t/b it should at least 60' half assed,even at 3800#.if it aint maken rpm very fast it's in the timing,ignition or cam.if it had fuel issues it probly would'nt rpm that high.too many things it could be but i'd say its a few things all together.ign timing too low and no advance or even a vac advance on a live vac port. study
I talked with the owner last night and the guy that degreed the cam in and from the both of them what you have stated is true. I talked with his son this evening and we are going to try and make it Friday night to crossville with his car and may try and take my car to B.G Saturdaynight.
whitefield
whitefield
Post  cool40 May 9th 2012, 12:03 am
good luck Wink
Post  dfree383 May 9th 2012, 12:13 am
Find a chassis dyno...... Its more productive.
Post  cool40 May 9th 2012, 12:16 am
but half the fun!
Post  whitefield May 9th 2012, 11:25 am
but half the fun!
Lee What time does TNT start on Friday nights at US43 ?
whitefield
whitefield
Post  cool40 May 9th 2012, 10:16 pm
whitefield wrote:
but half the fun!
gate opens at 5:00 run at 6:00
Post  whitefield May 9th 2012, 10:19 pm
cool40 wrote:
whitefield wrote:
but half the fun!
May not make it this weekend but dang sure going to try to next Friday ! Thank you sir Cool
whitefield
whitefield
Post  cool40 May 9th 2012, 10:28 pm
let me know when you can and i'll do my best to come help out. Smile
Post  whitefield May 9th 2012, 10:36 pm
I sure will thanks Lee
whitefield
whitefield
Post  cool40 May 14th 2012, 11:50 pm
Question
Post  whitefield May 15th 2012, 9:02 am
we didn't run this weekend weather and sicknes . We had the screaming ...... well you know Embarassed affraid
whitefield
whitefield
