oiling mods for solid roller cam?
torkair
oiling mods for solid roller cam? Empty oiling mods for solid roller cam?
Post  torkair September 25th 2009, 2:26 pm
JUst out of curiosity, are there any oiling mods that need to be done to a block when installing a solid roller cam? I havent seen anything on this so might as well ask.
torkair
torkair
oiling mods for solid roller cam? Empty Re: oiling mods for solid roller cam?
Post  BigBlockRanger September 25th 2009, 3:02 pm
No.
Post  maverick September 25th 2009, 3:23 pm
BigBlockRanger wrote:No.
I swear, James.....Your posts get more and more "wordy" every day. Laughing
Post  bbf-falcon September 25th 2009, 4:12 pm
The least I would do is drill a hole from the slot in the front cam bearing through to the dizzy gear. jmo
Post  Gregaust September 27th 2009, 7:11 pm
bbf-falcon wrote:The least I would do is drill a hole from the slot in the front cam bearing through to the dizzy gear. jmo
Yes absolutely , prevents a lot of bronze gear wear Wink It is outlined on Paul Kanes website on how to .
Gregaust
Post  72mav September 27th 2009, 7:29 pm
X2 on Paul Kanes site/info.
If youre gonna run it hard, you gotta prep it. Do whats listed in pauls info.And also.smooth the lifter valley. This helps get the oil BACK into pan, especially in a drag race application.
All it takes is a few seconds of oil starvation and there goes the bearings in a few passes. Shocked Embarassed Crying or Very sad
Keep us posted.
Regards.
Al
72mav
72mav
Post  torkair September 28th 2009, 12:49 pm
Since this is my first "385" tear down and rebuild Im trying to find out every last bit of info i can so that i can do it right the first time! Definately gonna check into every last little thing i can do to make this engine live.
torkair
torkair
