1964 falcon drag car with a 428 in it.... what front spring to put in the.....
Front.... has mustang II front suspension with tubular A-arms, manual rack steering, comp engineering drag shocks... my buddy replaced the stock 40 yr old springs last year with stock replacement springs. I don't know the spring rate just that he had to cut a coil and a half off the new springs to get the ride height back where it was with the old springs. What do you guys use for springs in your mustang II front suspensions? The car doesn't hook consistently now. Since this is the only thing he changed im thinking this is where the problem is. Front suspension doesn't have enough stored energy or enough travel. Car has a C6 and use to sixty foot in the 1.42-1.44 area running 10.50-10.80 ET's. Car weighs 3100 ready to race.Thanks
bluef100fe- Posts : 379
Re: 1964 falcon drag car with a 428 in it.... what front spring to put in the.....
Cody pm coon 61 he bought some for his 61 and they act like they will work fine. He ran into the same problem.
2WD Ranger PU springs are in mine. You'll needta shorten 'em up some. Not much for "stored energy" , but the front end don't drag.
JACKAZZFLATZ- Posts : 249
Talk to Corky at Applied Racing .com
He has great springs for all the O.E.M. replacement stuff.
Regards.
Al
Regards.
Al
72mav- Posts : 1081
After doing some more digging and guessing we are gonna try some 275 lb/inch springs... lowest rate we could find online for the mustang II front suspension. Best I can figure the oem replacement springs he has are 364 or 375 lb/inch thanks for the help guys.
» 1964 Galaxie Former Drag Car
» Falcon front drum to disc conversion.
» 1962 falcon front suspension
» front spring rate ...
» Front Spring Rate
» Front Spring Rate
