1962 falcon front suspension
1962 falcon front suspension Empty 1962 falcon front suspension
Post  johndickjr June 5th 2012, 5:32 pm
what other years of cars will fit the 1962 falcon, its currently 4 lug drum brakes and i want to swap ti to 5 lug disk brakes
johndickjr
1962 falcon front suspension Empty Re: 1962 falcon front suspension
Post  61coon June 11th 2012, 10:24 pm
I have never done this swap myself,but I know a guy who did. He used Granada/monarch spindles and disc brakes. He also had to use upper and lower arms off a 65-66 mustang. The falcon ball joints are a little smaller and the mustang ball joints are the correct size for the Granada spindles. Remember when you swap to front disc you'll need a dual-resivor disc/drum master cylinder. The unit for a '67 mustang should be a direct bolt-in. Hope this helps you out. ---RED
61coon
61coon
