Front suspension ?
whitefield
Front suspension ? Empty Front suspension ?
Post  whitefield March 11th 2013, 11:33 am
I was looking at some pics of my car and it got me to thinking ! It seems that the front wheels drop down more since I have change from the stock K member and spring set up to the coil overs and Qa1 K member.
So my question is would limiter help my traction , and or 60ft times and could it help overall et ?
Best 60ft is 1.44 .
whitefield
whitefield
Front suspension ? Empty Re: Front suspension ?
Post  bruno March 11th 2013, 1:06 pm
have you tried to stiffen up the shock first
http://WWW.CKRME.COM
Post  whitefield March 11th 2013, 8:21 pm
bruno wrote:have you tried to stiffen up the shock first
Yes and it still dropped way down as compared to stock k member and controll arms ! Mad
whitefield
whitefield
Post  IDT-572 March 11th 2013, 11:03 pm
are they double adjustable?
Post  whitefield March 11th 2013, 11:06 pm
IDT-572 wrote:are they double adjustable?
Single adj.Strange
whitefield
whitefield
Post  IDT-572 March 11th 2013, 11:10 pm
That is what is on mine, something must be wrong with yours. Mine will make a big difference from full loose to full tight.
Post  whitefield March 11th 2013, 11:18 pm
It makes a difference in the way the car reacts but the front tire drop down a whole lot lower now than they did with the stock k member and coil springs . same struts and setting on both suspensions. It just got me to think if there was something to it !
whitefield
whitefield
Post  IDT-572 March 11th 2013, 11:21 pm
My guess the stock a arms were frozen and not free to move. About all it could be.
Post  whitefield March 11th 2013, 11:25 pm
IDT-572 wrote:My guess the stock a arms were frozen and not free to move. About all it could be.
Could be! So what do you think about adding limiter ?
whitefield
whitefield
Post  IDT-572 March 11th 2013, 11:32 pm
I don't have them on mine with the adj struts, I can loosen them to full loose and stand it on the bumper or full tight and tires foot off the ground spinning. I wouldn't think you would need them if the struts were working correctly.
I think if you watch the car close the front tires may not be dropping fully until your a ways out. even at full tight I don't they will drop all the way by 100 ft or less.
Maybe Dave will correct me.............
Post  whitefield March 11th 2013, 11:37 pm
IDT-572 wrote:I don't have them on mine with the adj struts, I can loosen them to full loose and stand it on the bumper or full tight and tires foot off the ground spinning. I wouldn't think you would need them if the struts were working correctly.
By looking at the pics of your car your front wheels set up higher in the fender like mine did with the stock k member . May be nothing to it ! I will be testing in a few weeks and do some adjusting and see what happens.
whitefield
whitefield
Post  whatbumper March 12th 2013, 12:06 pm
Build you some from home depot parts and test it. If it doesn't work like you want then take them off. If they do work then use them. We run limiters on everything. With good or bad struts.
Post  richter69 March 12th 2013, 12:14 pm
limiters are just another tuning tool, as said fab u some up...........if they help then good....if not then not much time or money lost.
Post  whatbumper March 12th 2013, 10:35 pm
richter69 wrote:limiters are just another tuning tool, as said fab u some up...........if they help then good....if not then not much time or money lost.
Like Jon said. I would even go further and emphasize that limiters are not a band aid like some people think. Hell with my front end I have to run limiters or it puts stuff in a bind. I can't have as much travel as my struts allow.
Post  DILLIGASDAVE March 12th 2013, 10:44 pm
Adjusting the strut extension valving tighter & tighter doesn't reduce the total amount of avalible front suspension travel, it just slows down the speed at which any amount of that said travel is allowed to eventually happen.
Having the ability to adjust/limit the front suspension's total travel distance can help if it's what the car/combo in question really needs. Some cars migh work better with all the travel you can get, and some work better with less. Having both limiters & adjustable valving at the same time does increase the size of the usable adjustment window. Adjust total travel distance with the limiters, adjust the speed of that travel with the valving, both can work together.
It can't hurt to give them a try, as mentioned keep them if they help, remove them if they don't.
Post  whitefield March 12th 2013, 11:26 pm
Thanks for the good info ! study I will put them on and see how they do ! Thanks again.
whitefield
whitefield
