Front sub frame, 69 Mustang
jeffgfg
bowsher21
Front sub frame, 69 Mustang Empty Front sub frame, 69 Mustang
Post  bowsher21 February 24th 2016, 11:32 am
I have a client looking for front sub-frame ideas that have been used on a 69/70 style Mustang. He wants me to show him pictures of cars that have been rebuilt from firewall forward, either kits or "from scratch creations". Tubes will go through firewall to tie into 6 point cage.
bowsher21
bowsher21
Front sub frame, 69 Mustang Empty Re: Front sub frame, 69 Mustang
Post  jeffgfg February 24th 2016, 5:41 pm
The only one I know of that doesn't require alot of work is the one from Fatman fab. It is a complete front suspension replacement. It is a strut type kit. Total cost has a strut kit but uses the factory mounting points. Hope this helps.
jeffgfg
Post  res0rli9 February 24th 2016, 8:57 pm
here's a new one just out.
www.totalcontrolproducts.com/frontclip.html
www.cachassisworks.com/p-3339-full-subframe-clip-splined-arb-67-70-mustang.aspx
Post  bowsher21 February 24th 2016, 9:25 pm
Thank you gentlemen, that's what I am looking for. I'd also like to see some home built tube creations.
bowsher21
bowsher21
Post  jbozzelle February 27th 2016, 12:59 pm
Hit up richter69 on here. Jon homebuilt the front of his 69 with Fox Mustang style struts, etc...
Post  res0rli9 February 27th 2016, 7:56 pm
jbozzelle wrote:Hit up richter69 on here.  Jon homebuilt the front of his 69 with Fox Mustang style struts, etc...
Yes he has picks of it on here somewhere?
Post  bowsher21 February 27th 2016, 10:23 pm
I've been searching for the pictures. I seem to recall seeing them quit awhile back.
bowsher21
bowsher21
Post  bowsher21 March 3rd 2016, 1:33 pm
Looks like we will be going with a Heidts Pro g v2. This is a coil over system with Mustang II cross member. Thing is, Heidts doesn't have motor mounts for a 460 block/Mustang II frame. This car is a street car with a few trips to the drag strip, so, if I have to custom build motor mounts should it use a motor plate or OEM motor mount location.
What about headers to fit the Mustang II/460/ R&P steering set up?
bowsher21
bowsher21
Post  70FB March 3rd 2016, 7:57 pm
I went with the AJE kit and engine plate. A set of hooker super comps 2" for a fox body worked on mine except for two tubes near the steering shaft had to be changed.
70FB
70FB
Front sub frame, 69 Mustang Empty Front suspension
Post  67460 March 3rd 2016, 9:56 pm
Here is a site I use their front suspension mustang II work great.
http://rcmotorsportsinc.com/
67460
67460
Post  Jetman January 7th 2017, 4:42 am
I recently installed AJE's K-member in my 1970. 70FB seems to have travelled down the road that I am on; therefor, I am checking out his work. Currently I am seeking Hooker super comps for this set-up. I am building a 521 with SCJ heads.
Jetman
Jetman
