In car sub-frame connectors for a fox mustang
In car sub-frame connectors for a fox mustang Empty In car sub-frame connectors for a fox mustang
Post  tiger February 7th 2011, 10:31 pm
Can I see some pictures of some fox mustangs with the sub-frame connectors that go into the floor board of the car. I have been strongly advised to use those instead of the bolt on or weld on that go underneath.
What size steel?
tiger
In car sub-frame connectors for a fox mustang Empty Re: In car sub-frame connectors for a fox mustang
Post  Race Ready Fabrications February 7th 2011, 11:31 pm
Here's a pic of one I have done. I use 2X3X14 gauge. I'd advise that you make them as long as you can tying the rear to the front.
In car sub-frame connectors for a fox mustang Racereadyfab001
Post  tiger February 8th 2011, 12:57 pm
How far back and forward do those go? Do they go inside the frame any or just but up against?
tiger
Post  jbozzelle February 8th 2011, 4:10 pm
Run them from the firewall all the way into the rear subframe. You'll have to offset them since the front and rear frames do not line up with each other. I have some pics from my Futura I can post later today.
Post  Outlaw5.0 February 8th 2011, 6:08 pm
TeamZmotorsports sells weld in subframe connectors.
Outlaw5.0
Post  tiger February 9th 2011, 9:36 pm
After doing a lot of googleing I now understand how to do the front part, but I am still confused on the back sub frame. Do you just weld a plate on the back sub frame area where it meats the rear floor pan and then weld your tubing to that? Or do you cut a hole and run the tubing into the rear sub frame?
I found this picture. Scroll down a ways to the gray mustang that they built connectors in. The second picture where it shows the connection into the rear subframe is where I need clarity on what they did. This is what I had in mind for mine.
http://www.yellowbullet.com/forum/showthread.php?p=2145480
tiger
