New front suspension help!
D's557BBF
Hey guys, I'm changing out my front suspension and had a few question I thought I'll ask before spending all my money. I have a BBF, should be some place in the 9's. It's a foxbody hatch. 25.4 certified cage
1. is it a big deal to go with chromoly over mild steal?
2. what spring rate should i pick?
3. what drop on the rack do i need 1 1/2 or 2 1/2? or can i just use them k-member spacers?
4. which k-member brand are you using??
5. all info welcomed
D's557BBF- Posts : 1186
Re: New front suspension help!
im using a d and d k-member ( mild steel )with front and rear plates , 150lbs springs, strange adj. , upr camber plates and bump steer, flaming river rack ...with zero drop
i would run the upr c/m or the aje deal lots more room with these new updated k-members
The deal we put on the fox is a Team T we got from Jones, seems ok, I dont like how the lower arms are a 1/2" or so out further than stock.
bruno wrote:im using a d and d k-member ( mild steel )with front and rear plates , 150lbs springs, strange adj. , upr camber plates and bump steer, flaming river rack ...with zero drop
bruno, with no drop are you using k-member spacers??
what oil pan are you using? I have the canton oil pan...
watch what package you get, you will need to watch front wheel back spacing, unless you like the front wheels sticking out past the wheel lip..... Also watch what brake package you use it can make the situation even worse.
no k-member spacers , and a custom pan from Lem Evans
ps i had the canton pan before and it worked fine with this same k-member
richter69 wrote:The deal we put on the fox is a Team T we got from Jones, seems ok, I dont like how the lower arms are a 1/2" or so out further than stock.
That's because everybody builds their fox K's to 87-93 GT specs. The 79-86 car's (all ex. SVO) and 87-93 4 banger cars are 1" narrower than the later GT's.
BigBlockRanger- Posts : 1267
You mean Team Z? I saw Dave this weekend down in Georgia at the race.
I could have swore they was suppose to be the short a-arms.
jones- Posts : 2230
my typing sucks, yes "Z", and they stick out. If I had caught it in advance I would have cut them down myself...............but it aint no biggie............
Go ask team Z. Hell he is the "MAN" for Fox mustangs. Hes down in the Detroit area somewhere by you. Shouldnt be hard to find.
72mav- Posts : 1081
He is in Taylor Michigan
http://www.teamzmotorsports.net/Default.asp
jones- Posts : 2230
» Front suspension ?
» Mustang II or Ranger front suspension ?
» New steering/front suspension in truck
» Front sub frame, 69 Mustang
» Front suspension is coming apart again
