Head Gasket Question
Dying of curiosity!
I pulled my heads off my 460 for a trip to the machine shop monday and got to looking at the head gaskets. I never noticed before that some of the paths for the coolant across the top of the gasket between the cylinders are restricted by the gasket and one is even blocked off. My new gaskets are the same so I assume there is a reason.
WHY?
WHY?
Deviant- Posts : 4
Re: Head Gasket Question
Water enters the engine at the front and exits at the front. The head gaskets are designed to influence/equalize coolant flow to the rear of the block/heads before returning/exiting out the front. The hot spots are deterred in effect.
Paul
Paul
Thanks, I was pretty sure it controlled flow and alot of thought went into this, but you never really know till you ask. It seems that could have been addressed at the developement stage for this block.
BTW You have answered many, many questions for me on this and another forum through the search button over the last year. You have enlightened me repeatedly. I'm sure there are many of us out there silently searching, reading and learning from you and many others. THANKS
Deviant- Posts : 4
some of the big block ford gaskets block off diff ( size) holes then others, look in a catalog at a parts store and you'll see what im talking about, its not a big deal
call fel pro tech line if you want more info
BOSS 429- Posts : 2372
» HEAD GASKET QUESTION
» Head gasket question
» head gasket question?
