Total seal support rail
Total seal support rail Empty Total seal support rail
Post  tconnection May 22nd 2012, 1:08 am
My rails and instructions were in a pack together and were file fitted along with rings. I didnt get my instructions for rail assembly or gap and dot position back. Do i need to call total seal or can it be simply explained to me here?
tconnection
Total seal support rail Empty Re: Total seal support rail
Post  bbf-falcon May 22nd 2012, 9:43 pm
I never had to gap my rails. Just make sure they are positioned correct as the ring instruction sheet says. W/Total seal just make sure they are the correct ones Rolling Eyes
Post  cool40 May 22nd 2012, 10:03 pm
bbf-falcon wrote:I never had to gap my rails. Just make sure they are positioned correct as the ring instruction sheet says. W/Total seal just make sure they are the correct ones Rolling Eyes
x2,brc sent the wrong ones to me. Shocked
Post  tconnection May 22nd 2012, 11:53 pm
Oh, my bad. They're Diamond rail supports that came with the pistons.
tconnection
Post  cool40 May 22nd 2012, 11:58 pm
tconnection wrote:Maybe im calling these thing by the wrong name. Im not talking about the oil rings. This rail here goes under the bottom oil ring. The ring instructions dont have any info about them.
yep,i know what you talking about.i just put some on today and did'nt do anything to them,just put them on.mine had a dot or more like a punch mark on them that goes in the pin hole area with the bump turned down.
Post  tconnection May 23rd 2012, 12:12 am
Thaaaat's what im wanting know, where to put that dot. The shop got the ring packs taped together and numbered.
Thanks again
tconnection
Post  tconnection May 23rd 2012, 12:20 am
Oh, which pin hole, front or back? When you said bump, are you talking about the dot?
tconnection
Post  cool40 May 23rd 2012, 12:28 am
tconnection wrote:Oh, which pin hole, front or back? When you said bump, are you talking about the dot?
its a bump,like you hit it with a punch and hammer.it should go in the wrist pin hole with the "dent"down so it wont push up on your oil ring.thats how mine are......some may work other ways confused make sure you know before you put it together. Laughing that "dent"would be to keep it from turning in the bore
Post  tconnection May 23rd 2012, 12:34 am
Ok sound good. Thanks man!
tconnection
