radiator combos you guys are running and reccommend for fox
+9
stanggt
Mustang-junky
Barney
5pointslow
13 posters
looking to get a radiator fan combo for fox drag car
if it matters iron headed engine
was looking at the ron davis stuff looked good , but was wondering i see some have pressure caps and some dont , also some outlets are stock style hose and some are pipe fittings
what are your guys opinions on this ?
5pointslow- Posts : 1408
Re: radiator combos you guys are running and reccommend for fox
im running a fluidyne, with a dual fan setup
reg hose style outlets or fittings?
5pointslow wrote:reg hose style outlets or fittings?
yes reg hose style
I have a custom deal made for me by PRC. It's larger than the standard Fox stuff with AN fittings, and I used two pusher fans in the front with mounting brackets I made myself.
Early photo during the build.
Lot's of cars of all brands, (street ... street / strip ... racing), around here use the aluminum radiators for asphalt oval track racing available from HOWE RACING and other places.
Of course Howe Racing is in the middle of lower Michigan so, that may have a lot to do with where they come from but, I am sure there are vendors of oval track stuff all over the country.
I run a griffin with dual pullers and traditional hoses, but wil
Be switching to -16an and stainless for safety asap
If you don't mind being made in China, these are real nice and dirt cheep.
http://www.ebay.com/itm/3-Row-w-o-EOC-w-TOC-All-Aluminum-Radiator-2-3-5-0-2-4-3-3-3-8-L4-L6-V6-V8-/290712502995?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AMustang&vxp=mtr&hash=item43afd0c2d3#ht_4172wt_932
I bought one recently for $125 shipped from these people, it came in two days.
Jess
Jess
Mustang-junky- Posts : 438
rmcomprandy wrote:Lot's of cars of all brands, (street ... street / strip ... racing), around here use the aluminum radiators for asphalt oval track racing available from HOWE RACING and other places.
I'm using a Howe 19"X31" Radiator in my 89 Mustang with a 466 BBF.I'm also using a waterpump driven 15" Mechanical Fan.I also have a 12" or 14" Electric Fan in the front of the Radiator for when i'm driving at slow speeds.
Later Mark.
Mark Miller- Posts : 1959
I'm running a regular aluminum fox fit rad with std hoses and dual electric fans.
whats the deal with pusher and puller fans , i understand the diff but whats the gain between the two ? is it space ?
Have 2 pulling, other than space I can see no advantage to pushing.
my car was set-up with a Griffin aluminum rad and a pusher,it consistantly got hot at slow speeds. Switched it around to pull and it was fixed.IMO pulling is much better if u have the room.dfree383 wrote:Have 2 pulling, other than space I can see no advantage to pushing.
stanggt- Posts : 494
We don't run them. Couple gallons of ice water and a small bilge pump in tank. Lines straight to heads. Oil heater on pan. Burn out at 50-55° get back to pits around 120-125°. This was the last nitrous car running mid 5's with the SBF.
whatbumper- Posts : 3024
whatbumper wrote:We don't run them. Couple gallons of ice water and a small bilge pump in tank. Lines straight to heads. Oil heater on pan. Burn out at 50-55° get back to pits around 120-125°. This was the last nitrous car running mid 5's with the SBF.
alum. or steel rods ?
Ron Davis with AN fittings no problems here
studly- Posts : 512
bruno wrote:whatbumper wrote:We don't run them. Couple gallons of ice water and a small bilge pump in tank. Lines straight to heads. Oil heater on pan. Burn out at 50-55° get back to pits around 120-125°. This was the last nitrous car running mid 5's with the SBF.
Aluminum. 180 oil temp
I'll be doing an ice tank this winter, I just tossed the radiator back in for now due to lack of time.
I run a dual SPAL puller fan setup (same as BeCool) I got off ebay and a BeCool fox body aluminum radiator that I got directly from BeCool. BeCool built the radiator for me with a larger 1 1/2" inlet and a 1 3/4" outlet to better match up with my BB. Best part was they sold it to me for less than the normal retail price!
GTmustang- BBF CONTRIBUTOR
» what kind of setup you guys running waterpump wise an fittings or regular hose with clamps ??
» whats your guys take on running a dry sump set- up?
» Dragster guys. What are you running for a trans overflow can?
» 4.5" Scat cast crank, how much HP are you guys running through them?
» Stock stroke/rod chevy piston combos
