580ci a460 head & a 460 block
+32
Larry T
Mustang-junky
Tony M
larry552
butterbean
gmsmkr
70FB
460pulling
Dark Horse of Apocalypse
nastynotch600
J.Toney
ThndrChkn
nuclearcobra
kjett
bb429power
soupbean
norm
QtrWarrior
devildog
fordman50
tconnection
36 posters
Page 2 of 6 Previous  1, 2, 3, 4, 5, 6  Next
580ci a460 head & a 460 block - Page 2 Empty Re: 580ci a460 head & a 460 block
Post  tconnection August 7th 2012, 10:23 pm
Ok, thanks Mr.C. Yea it's external but it's eagle 4340. I bought this crank from cnc-motorsport. It was turned down .010 on the mains by eagle. It had a orange tag on the snout that said external balance about two years ago.
tconnection
Post  soupbean August 7th 2012, 10:31 pm
Just curious, are you going to dyno this thing before it goes in the car?
soupbean
soupbean
Post  bb429power August 7th 2012, 10:41 pm
tconnection wrote:It's a sunburst orange pearl matalic
An auto teacher at my high school painted his foxbody with that, had a sbf in it. The color looks even better in person Cool Cool deal
bb429power
bb429power
Post  tconnection August 7th 2012, 10:49 pm
I wasn't but I may check around and get it done. May borrow some money from myself and see what's up with it.
tconnection
Post  tconnection August 7th 2012, 10:56 pm
Oh yea. it looks pretty good. I had to water sand and buff like crazy. Can't wait to see it with the motor in it,
extended hood, 3.5's and something fat on the back.
tconnection
Post  soupbean August 7th 2012, 11:02 pm
The reason I ask is I am beginning the process of building something similar after breaking my 557 a head this past weekend. I enjoy seeing others numbers on the dyno and the track as well. I hope she is a beast for you. What are the details of the build if you dont mind me asking?
soupbean
soupbean
Post  kjett August 10th 2012, 9:39 am
tconnection wrote:I wasn't but I may check around and get it done. My borrow some money from myself and see what's up with it.
It's worth it to put it on a dyno. Especially if the guy running the dyno is willing to help you get it tuned properly. Makes life much easier getting the correct timing and jetting where you can see the gains/losses instead of burning the motor down trying to tune at that track or by using your ultra calibrated ear. Shocked
kjett
kjett
Post  nuclearcobra August 10th 2012, 10:05 am
jasonf wrote:It is large just because that is the size it was. If you want it you need to resize it. Photobucket has to the tools and it only takes a couple clicks.
When you hover your mouse over the picture in photobucket a menu will appear at the top of the picture. Third from the left will be "resize". Just select the 600x800 (or any size but that is a good one) and it will resize it for your. Then just select save.
To post multiple pictures you just need to do one after another. Each pictures has to be done individually.
Yes you just have to hold the ctrl button after the first picture to load multiple pictures in the same post
nuclearcobra
nuclearcobra
Post  69F100 August 10th 2012, 3:40 pm
the only one i know of around here is a chassis dyno in Tifton Ga but you will need a set of street tires or drag rad to use he want run slick on the dyno
Post  tconnection October 9th 2012, 2:05 am
Here's a few more pics.[img][/img]580ci a460 head & a 460 block - Page 2 HPIM0471[img][/img]580ci a460 head & a 460 block - Page 2 HPIM0470-1[img][/img][img:a680]https://i381.photobucket.com/albums/oo259/tconnection/HPIM0580ci a460 head & a 460 block - Page 2 HPIM0467469.580ci a460 head & a 460 block - Page 2 HPIM0469jpg[/IMG][img][/img][img][/img]
tconnection
Post  bruno October 23rd 2012, 7:28 am
looks great man cheers
http://WWW.CKRME.COM
Post  tconnection October 23rd 2012, 10:38 pm
Thanks, Im building headers now and they'er kicking my butt. Bout got'em though.
I think uma have to do away with them big ass valve covers because of the master cylin580ci a460 head & a 460 block - Page 2 HPIM0475der space.[im580ci a460 head & a 460 block - Page 2 HPIM0477g][/img][img][/img]
Last edited by tconnection on October 25th 2012, 10:27 pm; edited 2 times in total
tconnection
Post  soupbean October 25th 2012, 7:04 pm
Skinny Kid race cars make an offset adapter to shift the master cylinder over for more valve cover clearance.
soupbean
soupbean
Post  tconnection October 25th 2012, 10:40 pm
Thanks, im gonna have to check one out.
tconnection
Post  tconnection April 25th 2013, 10:45 pm
Im about to fire this engine up? Is there a certain rpm and run time I need to acheive?
tconnection
Post  ThndrChkn April 26th 2013, 11:32 pm
tconnection wrote:Im about to fire this engine up? Is there a certain rpm and run time I need to acheive?
Given the app, I'm gonna take a stab, and say it doesn't have a flat tappet cam in it... A roller cam requires no real break-in per say. I just get it fired, and up to temp, set timing, check for leaks, or any other issues, play a little bit just to hear it bark, and shut it down. Everybody has their methods, but I like to let mine cool down, then check the valves... I set mine cold, and periodically check them hot to make sure they're staying put... Like I said, everybody has their own methods...
Oh yeah, Nice car... Cool
ThndrChkn
ThndrChkn
Post  bbf-falcon April 27th 2013, 8:22 am
X2. Good luck w/it. Looks killer. Wink
Post  tconnection April 29th 2013, 12:20 am
Thanks men. And like Si Robertson say, Hey! i fired that babe up today, Jack.
It was wild. I didn't let it run no longer than brought some good heat to the heads.
I had a couple issues in the beginning with the regulator and the coil.
I havent set the timing yet but what i did do was put the pointer on like 12* and pointed the button at the number one terminal but it seems like it might want more which of im gonna put a light on it. About what's a good timing number for n/a? The carb is a 1250 quick fuel that a buddy let me fire up with. The idle screws are only a little over a half turn out.Do you think it need atleast a full turn? I mean when i take my hand off the hammer it will shut down. I keep it going until i got some good heat to the heads then let it shut down. What do you think?
Thanks for any info.
tconnection
Post  norm April 29th 2013, 6:04 pm
Mine is at 32 degrees. I usually start with idle mixture screws out a turn and a half and fine tune from there.
norm
norm
Post  Lem Evans April 29th 2013, 7:13 pm
Like has been said..... 1-1/2 turns is a good place to start. If the engine wants less than 1 turn the jets or air bleeds are not correct.
Post  tconnection April 29th 2013, 10:00 pm
Ok, thanks! As for lashing the valves, is it a rule of thumb that if you're setting your lash to 26 that you shouldn't be able to get 27 in it? Or if 27 will go in, you would have to push pretty hard?
Thanks for all info.
tconnection
Post  69F100 April 30th 2013, 12:28 am
no you should not be able to put the .027 in it if you can then you have it set for .027 tight
Post  J.Toney April 30th 2013, 11:49 am
Can we see any specs on this build?
J.Toney
J.Toney
Post  tconnection May 1st 2013, 11:43 pm
Since im not a grudger, sure. 580ci, trickflow ahead with the 2.35 valve ported by me and the trickflow intake lightly ported and port matched and gasket matched. A460 block, fordged eagle crank and H beam rods, diamon gas ported pistons. Custom comp double pinned with 7/16 bolt, 839int/780ex, 283/302 @.050, that might be 284 instead of 283, 316/340 @.020. The heads are 428cfm @ 800 out the box so with porting that i did im figuring i got atleast 12 to 15 extra cfm. May be 440 on the intake. I didnt dyno so i dont no how much hp its making but its a lot.
Any figures on hp? 12* initial timing would be about what total timing?
tconnection
Post  norm May 2nd 2013, 8:48 pm
What distributer are you using? A msd with a 20 degree advance bushing would total around 32. 12+20=32. I would still check total with a light. HP 900-975?
norm
norm
