Neutral safty switch wire
bigblok2000ranger
tconnection
Neutral safty switch wire Empty Neutral safty switch wire
Post  tconnection June 12th 2012, 11:00 pm
To get a 92 mustang to crank with a c6, does anybody know which wires right off to connect?
tconnection
Neutral safty switch wire Empty Re: Neutral safty switch wire
Post  bigblok2000ranger June 12th 2012, 11:32 pm
Was the car originally an auto or a manual? If it was a manual splice into the wires that went to the clutch safety switch and if it was an auto there should be a 4 wire plug that comes through the floor right about where the shifter arm is I usually pull the plug back up into the car because 2 wires are for nuetral safety switch and 2 are for reverse lights. I don't recall the colors but real easy to determine which are which, one should have power with key in run position that is the reverse light wire and one should only have power in the start position that is the nuetral safety switch wire the wires directly across the plugin goes to the lights or solenoid respectively. If you push the grommet into the car form underneath and have long arms you can grab the plugin and pull it up to your new shifter easily.
bigblok2000ranger
bigblok2000ranger
Post  tconnection June 13th 2012, 12:38 am
i got lost at the end so im just gonna ask, do the two neutral wires connect together? Im not hooking to the shifter.
tconnection
Post  bigblok2000ranger June 13th 2012, 8:43 am
If you are bypassing that feature yes. I don't suggest it though.
bigblok2000ranger
bigblok2000ranger
Post  whitefield June 13th 2012, 2:27 pm
Here is a diagram that may help http://www.veryuseful.com/mustang/tech/engine/images/fuel-alt-links-ign-ac.gif
whitefield
whitefield
Post  the Coug June 13th 2012, 2:49 pm
tconnection wrote:i got lost at the end so im just gonna ask, do the two neutral wires connect together? Im not hooking to the shifter.
I suggest you hook it up if not Most tracks test it and if it doesn't work you don't race...
Post  maverick June 13th 2012, 4:14 pm
I saw a guy fire up his car in the staging lanes....it was in gear. He only smashed two race cars because the guy standing between them jumped clear. Wire the switch.
Post  dr's wife racing June 13th 2012, 9:00 pm
I've seen a accident due to this to.You know the wires run it thru rhe switch and your done,
dr's wife racing
dr's wife racing
Post  tconnection June 13th 2012, 11:17 pm
The car aint mine but but i do wanna hook the switch up. The car has the stock shifter so that's a plus. That's really dangerous.
tconnection
