C6 clutch clearances???
C6 clutch clearances??? Empty C6 clutch clearances???
Post  bigblok2000ranger June 13th 2012, 3:24 pm
I am putting my trans back together with Merkl brake vb and Rcode servo with billet E lever, I had been setting forward clearances at. 062" and direct at. 072" but was warping clutchs and steels with a TCI manual reverse vb so this go around I set forward at .049" and direct at .051" reverse is at .050 (no issues with them). Does this sound good?
bigblok2000ranger
bigblok2000ranger
C6 clutch clearances??? Empty Re: C6 clutch clearances???
Post  whitefield June 13th 2012, 4:48 pm
The reverse high clutch stock settings with three clutches is .022 to .036 so on the high side of this with 5 clutchs I would put it at .050 to .060.
The stock forward clutch pack settings are .021 to .046 with 4 clutches and on the high side of this with 5 clutches .058 so I would put these at .048 to .060.
Just my two cents !
whitefield
whitefield
Post  richter69 June 13th 2012, 5:14 pm
I agree w this ^^^^, could even go a bit tighter on the forward............seems for a 6 disc fwd in 4r100 I go .035-.040, and w 8 in the direct I go like .040....................but thats a low rpm diesel deal.
Post  Frank Merkl June 13th 2012, 7:31 pm
set the direct at .012-.013" per clutch
Post  bigblok2000ranger June 13th 2012, 7:33 pm
I talked with Mark on the phone earlier and the clearances are all good. All clearances range from .049-.051". This trans has red altos in all clutch packs including reverse (I know overill but...). The clutches and steels in reverse looked like the day I put them in so they went back in.
bigblok2000ranger
bigblok2000ranger
