teflon or metal sealing rings in full race c-6
teflon or metal sealing rings in full race c-6 Empty teflon or metal sealing rings in full race c-6
Post  BUZZ BUZZARD June 16th 2012, 8:03 pm
about to go through my c6 any opinions on teflon rings vs metal sealing rings?
trans is fully rollerized now with teflon rings but having problems with burning high gear clutches.
first time it happened I had cut one of the rings on the direct hub fixed that and tripple checked rings but still had slugish 1-2 and 2-3 shift and smoked clutches in four passes. Gona swap pos tci valve body to my old transking pro brake.
BUZZ BUZZARD
teflon or metal sealing rings in full race c-6 Empty Re: teflon or metal sealing rings in full race c-6
Post  Frank Merkl June 16th 2012, 9:44 pm
teflon is the only thing to run , fill the sealing ring groove with vaseline to keep the sealing ring in place on assemble
Post  Gregaust June 17th 2012, 4:54 am
Definitely teflons .
Gregaust
Post  BUZZ BUZZARD June 17th 2012, 12:06 pm
Thanks for the input. Frank since you have one of the fastest c-6 trans cars I have heard of, can you tell me what rear gear you are running or at least suggest a gear ratio on my car. It has a best 60' of 1.29 foot brake, 9.20 1/4 at 152mph, 5400 9.5 inch spragless convertor by Paul Yerger, 33x15x15 MT slicks, stock low gear, 4.11 rear gear. I shift the car at 6500, go through at 6900. I will be transbraking the car when it goes back out. The car weighs 2900lbs + or -
Your input is appreciated!
BUZZ BUZZARD
Post  richter69 June 17th 2012, 12:11 pm
teflon for the win......
Post  Frank Merkl June 18th 2012, 9:42 pm
Buzz were running a 3.89 rear gear with a 7.60's @ 187mph
Post  BUZZ BUZZARD June 19th 2012, 8:19 pm
thanks!
BUZZ BUZZARD
