1.72 to 1.8 rockers
1.72 to 1.8 rockers Empty 1.72 to 1.8 rockers
Post  BUZZ BUZZARD July 8th 2012, 8:15 pm
If the propper springs are used is there any ill effects of useing 1.8 rockers to bring up the lift on a sollid roller?\
any oppinions?
BUZZ BUZZARD
1.72 to 1.8 rockers Empty Re: 1.72 to 1.8 rockers
Post  richter69 July 8th 2012, 8:34 pm
that and as long as everything clears...................its done all the time.
Post  dfree383 July 9th 2012, 4:00 am
^^^^ What Fabio Said..... If your on the edge with your cam now, meaning very agressive lobes, you want to check with the manufacture and see if the springs and other parts are up to the extra timing your going to gain.
Post  rmcomprandy July 9th 2012, 10:42 am
Yes, it is done all the time if there is enough "piston to valve", "retainer to guide" and "valve spring coil bind" clearance but, be careful.
IF the flank rates of the camshaft are very aggressive, the extra aggressiveness and loading which will be exerted at the valve MAY cause other problems.
