Siamese Bore Ford Block
The Block Ford sells in the catalog doesn't have water holes between the cyclinders it says in the catalog. Do these engines have a tendency to get warm faster than a passenger car block? Would there be a probloem running one in a street car?
Tore
Tore
Tore- Posts : 865
Re: Siamese Bore Ford Block
"This is the first cruise for this engine with a hood on the car. It was in the mid/upper 80s and fairly humid here in metro Detroit today. The car ran hotter with a hood than without (naturally), aprox 10 degrees more.
So the question is this... Is 195 terminal temp during sustained cruising (2500-3000rpm) with spikes of aprox 205 degrees under thrashings, and aprox 190ish during times of coasting, or long stops. TOO hot of a water temp? This is with a 180 thermostat. Should I go back to the 160?
Car ran fine. I didnt get on it too much (still a little nervous about the air cleaner hitting the scoop. Fairly tight tolerances!
Shane"
___________________________________________________________________________________________
1970 Torino GT with a 572" P51 engine....pump gas.
My personal experince is with the R.E.D. that P. Oakley bought from David Cole a few years ago.
It came with a 588" A460 headed engine....it was later replaced with a 547" FRPP SCJ head deal [4.400" bore] with a factory SCJ 4 bolt block. Same rad./hoses/pump....the A460 blocked engine ran about 10* cooler.
I know what most of you are thinking....I'd declare B.S. myself if I hadn't seen it with my own eyes.
Shane"
very interesting,I expected the opposite.
Thanks Lem: Tore
Thanks Lem: Tore
Tore- Posts : 865
With a new OEM vehicle, the fan switch doesn't even trip the electric fan on until 218 degrees.
Some of the new Mustangs are well over 600 horsepower.
Tore wrote:very interesting,I expected the opposite.
Thanks Lem: Tore
Maybe it's not the blocks. Maybe the bigger TFS A460 heads run cooler than the FRPP SCJ heads....we may never know for sure.
» New 57 Ford Project Should we go big block or small block? Pics added
» how much is a 1972 429 4bolt cobra jet block worth.. Just the block and main caps.??? std bore
» How much do you bore out of an A460 block @ 4.600"?
» block max. bore
» block max. bore
