new lesson
samiam
Larry Williams
new lesson
I learned something new today. When I started my new motor I had no oil pressure. after a few hours of wasted time and not wanting to pull the motor again it dawned on me. WARNING. do not mix up the lines to the remote oil filter it will block oil pressure.
whew.
whew.
Larry Williams- Posts : 884
Re: new lesson
So, did it actually have pressure?
jbozzelle- Posts : 3705
Re: new lesson
Cheap insurance,,,,,,,,, I have an old distributor that I removed the gear from and welded a 3/8 piece of round stock to the top, with a power drill ,I always pre-prime a new engine
samiam- Posts : 240
Re: new lesson
i did prime it by hand both on the stand and before I installed the distributer then I removed the filter from the block and installed the remote filter. It showed no pressure on the guage till I discovered why
Re: new lesson
i also have a remote oil filter on my 460.
Just curious, what brand filter were you using when it happened?
Thanks for posting this.
The filter must have a check valve in it to prevent reverse flow
jmf32- Posts : 48
Re: new lesson
i was using a K & N just for break in
Re: new lesson
I blew up a 302 back in the early 90's on my first V8 Ranger swap that very same way. Ever since I am super careful that the outlet line from the block adapter goes to the inlet side of the filter adapter. I was young and dumb and excited back then lol.
I believe it is actually the anti drainback valve that stops them from working backwards.
Re: new lesson
interesting,
reminds me of when i was blowing head gaskets at the dragstrip at half track.
i finally found that i pinched the fuel pump eccentric against the timing gear
3 head gasket changes later that is
jmf32- Posts : 48
Re: new lesson
jmf32 wrote:interesting,
Can you explain how this was causing head gaskets to blow???
lghting94- Posts : 762
Re: new lesson
yes, the gasket blew due to the fact that the engine was leaning out of fuel all at high rpms.
meaning aprox 4800 or more rpms
the fuel pump eccentric was bolted to an aftermarket timing gearset.
the timing gear set was a nice piece, multiple keyways to advance or retard the cam.
i still have it but i had to mill the face of the larger gear so that it would not squeeze against the eccentric that drives the fuel pump.
i believe that it was not designed to be used with a mechanical fuel pump and i did not notice it when i rebuilt the engine
jmf32- Posts : 48
Re: new lesson
Reversing the lines to a remote filter won't show any signs of being wrong UNLESS the filter has an Anti-Backflow valve.
I have done simple oil changes in boats and on several new Mercruiser set-ups which inadvertently had the lines reversed originally from the boat builder, installing a better filter with an anti-backflow valve, shows that problem immediately
Took me a while to figure that one out; (how can just doing an oil & filter change cause and engine to have no oil pressure on just one of a pair of engines...?)
