460 main bearing issues
Hey motorheads I am new to this for Big Block 385 seris stuff and have stumbles upon an issue. It is going into a 71 Cheetah MFG jet boat, Berkeley drive. Couple months ago I tore it down hoping to just but a rebuild kit into it. Well...... bored .030 over, balanced, new pistons, marine cam and lifters, crank .010 grind, well you get the picture. Now on reassembly I have an issue with main bearing clearances, rods check out. I have .006 on the mains. what happened I used (Cb816p8-10;11-818p8-10) bearing kit from the "best motor builder at NAPA". I don't know what way to run with this. It is my understanding that bearing sets come in .010 increments. Or is there a .015 set out there? Any advice would sure be appreciated. Thanks to all
Craig
Craig
achey- Posts : 2
Re: 460 main bearing issues
Welcome Craig, glad you stopped by!
As to your bearing issue, if possible measure the crankshaft's main journal diameter to validate the dimension. If the dimension is valid, measure the torqued main cap with bearing halves in place. If that dimension seems odd, measure the torqued main caps without the bearing halves. Consult your machinist and/or return the bearings to the store.
Dave.
Dave.
LivermoreDave- Posts : 972
Thanks Dave, I have already talked to the machine man and he is getting my the grind sheet. I will get the measurements and compare.
achey- Posts : 2
Stick the old bearings back in and check what kind of clearance they had. It might give you some insight.
Exactly how are you attaining your bearing clearances? With Plastigage? Or via micrometer/bore gauge?
Paul
Paul
also where, there is greater clearance at the cap parting line, less cap to block bulkhead, seems like a no brainer, but some people where never told.
kim- Posts : 700
» Rod & main bearing clearace issues
» bearing clearance issues...
» what main bearing
» main bearing gap
» rod and main bearing's
» what main bearing
» main bearing gap
