Rod & main bearing clearace issues
I have .0015 clearance on rods & mains measuring with plasti-gauge. I know its not a very acurate way of measuring but its all i have. The rods are .020 under & mains are .010 under. The engine is a low budget bracket motor & will only see about 6200 rpm at the most. Will that be enough clearance or should i order different bearings they are king race bearings?
mustangjeff- Posts : 87
Re: Rod & main bearing clearace issues
Being they are .020 under, I'm not sure you can get x brg's for it. But .0015 is to tight.
JMHO
JMHO
Should i have the crank polished down a little or what is the easiest fix?
Before I would polish the crank, I'd have everything measured with something besides plasti-gauge. Then you will know for sure what route to take. Polishing is certainly an option if needed.
Nevs- BBF CONTRIBUTOR
Plasti Gage is not the best way to gage clearance BUT, it will give you an indication if a problem is lurking. It's a good chance that they are a little tight. Good Luck Brother
one way of getting some extra clearance (polished) bring a rod/bearing/s to the machine shop and have them measure the cl . was the rods resized ? if so might have big end to small. see that a lot , don't let them cool and reading is inaccuratemustangjeff wrote:Should i have the crank polished down a little or what is the easiest fix?
DanH- Posts : 1081
Thanks for all the help, this is a great site with good knowlagable people.
» 460 main bearing issues
» bearing clearance issues...
» main bearing gap
» rod and main bearing's
» Rod and main bearing .
» main bearing gap
