Rod and main bearing .
whitefield
Rod and main bearing . Empty Rod and main bearing .
Post  whitefield August 31st 2014, 5:54 pm
From your experience what brand of bearings do you guys use in or on cast steel crankshafts ? Thanks
whitefield
whitefield
Rod and main bearing . Empty Re: Rod and main bearing .
Post  cool40 August 31st 2014, 7:11 pm
King king
Post  IDT-572 August 31st 2014, 8:31 pm
King, is what I normally use, but if all is right I have have had good luck with clevite and several other brands.
Post  whitefield August 31st 2014, 9:24 pm
So next question comes to mind ! What type of bearing to use h bearing p bearing ect ?
whitefield
whitefield
Post  IDT-572 August 31st 2014, 9:28 pm
Mike, your H brgs are for a crank with a generous radius at the bearing surface edge. They will have a bevel on one side or the bearing will just be about .060 more narrow. the P is for a stock crank with little to no radius and full width. the material may be of a different formula too.
Post  whitefield August 31st 2014, 9:54 pm
Hp loss with grooved or none grooved main bearings ?
whitefield
whitefield
Rod and main bearing . Empty Brg Grooving
Post  504T September 1st 2014, 12:18 am
Some light reading.... Smile
http://www.mahle-aftermarket.com/C125790900540AC0/vwContentByUNID/D0AA4BBD7A61B745C1257B41005AA54A/$FILE/TB2051.pdf
504T
504T
Post  rmcomprandy September 1st 2014, 9:51 am
Whatever ones get me the clearances I want ... sometimes half of two different brands.
Post  bbf-falcon September 1st 2014, 1:15 pm
[quote="rmcomprandy"]Whatever ones get me the clearances I want ... sometimes half of two different brands.
X2,that and the RIGHT bearing for your crank/rods is more important than the brand.
Post  IDT-572 September 1st 2014, 1:29 pm
rmcomprandy wrote:Whatever ones get me the clearances I want ... sometimes half of two different brands.
mine has two different sets in it now and one main as a coated on one half and a uncoated on the other.
Post  whitefield September 2nd 2014, 12:43 pm
504T wrote:Some light reading.... Smile
Thanks for the read ! I was just concerned with all of the different types of bearings and there intended use study
whitefield
whitefield
Rod and main bearing . Empty More...
Post  504T September 2nd 2014, 7:48 pm
Try this... http://www.stealth316.com/misc/clevite-77-rod-main-bearings.pdf
and there is more here!! http://www.mahle-aftermarket.com/MAHLE_Aftermarket_NA/en/Products-&-Services/Support/Technical-Bulletins
Hope this helps, Kurt
504T
504T
