WONT GO INTO REV!!
WONT GO INTO REV!!
I have a Powerglide with a M&M pro trans break in it. The Trans will hold the mustang in 1st gear on the break LIKE IT IS SUPPOSE TO. But when you put the Trans in rev and hit the Trans break the car will NOT MOVE.
All help suggestion is greatly appreciated!!
Thanks, D
Thanks, D
D's557BBF- Posts : 1186
Re: WONT GO INTO REV!!
Denaro some of those trans brakes you have to have the trans in Neutral and hit the trans brake button. some you put in Reverse and hit the button.
the Coug- Posts : 3055
make sure the linkage is adj correct, if it is contact the builder.................
did you find the problem ??
No I didn't bruno...
I know it's not the cable because i disconnected that and manually put the car in reverse and it didn't work.
I put a call into M and M Trans where the Trans brake came from, I should know by the end of the day if I have to take it out or not!
the Coug wrote:Denaro some of those trans brakes you have to have the trans in Neutral and hit the trans brake button. some you put in Reverse and hit the button.
I tried this too coug.....NOTHING!
have you checked the nutural safty switch,just a guess?
Larry T- Posts : 1076
» 78 F150 460 ENG Oil Pan Wont Come Out
» wont idle / help please
» 55 staight axle swap 02 ranger ifs donor truck
» 84 CJ7 258 I6 - wont start
» Trans brake wont work on my c6
