wont idle / help please
wont idle / help please Empty wont idle / help please
Post  ape550 May 28th 2014, 9:37 pm
New member so I appreciate any help here! I recently purchased a 66 Falcon with a 429 in it. It started up nicely without even touching the throttle. Idle great after a brief warm up. Heard a rattling sound around cyl 1 & 2 area of valve cover. found very loose rocker and neverless a bad cam lobe and lifter. not knowing what was in it I pulled it apart and found a comp cams 305H10 cam. I called and ordered the exact same replacement with a set of lifters. right away it ran shitty. will not even attempt to idle with throttle stop screw letting it go below 1500 - 2000 rpm. double checked everything, even pulling front cover again and checking timing marks. compression is 220 - 240 on all cyl. plug wire routing correct. nothing had been altered on the carb. did find almost white plugs on cyl. 1,5,and 8. vac leak around manifold???? I used exact same part number intake gasket as well but who knows. has offenhauser port o sonic single plane. has been port matched. 750 dbl pumper. only thing diff is cam lifters and gaskets. gonna try to smoke the intake tomorrow I guess. Thanks for any ideas.
ape550
wont idle / help please Empty SOUNDS LIKE you wiped a lobe off the cam
Post  capncruncher1965 May 28th 2014, 11:26 pm
THATS why I think iam going roller in my new build
capncruncher1965
capncruncher1965
wont idle / help please Empty Re: wont idle / help please
Post  dirt_worker May 28th 2014, 11:31 pm
How are you valves adjusted? Maybe too tight?
dirt_worker
dirt_worker
wont idle / help please Empty I AGREE dirt worker
Post  capncruncher1965 May 28th 2014, 11:36 pm
IT JUST nerve racking breaking in flat cams nowdays LOL
capncruncher1965
capncruncher1965
Post  Dave C. May 29th 2014, 12:10 am
Vacuum leak.
Dave C.
Post  ape550 May 29th 2014, 8:54 am
valves were set a 1/2 turn past zero lash. Have already been backed off a 1/4 turn to check that theory. Sure it has to be a vac. leak somehow. Will update on tonites findings.
ape550
Post  Dave C. May 29th 2014, 9:07 am
Assuming "bad" means the lobes are down on it. If so you'll have metal in the engine . I'd tear it down.
Dave C.
Post  69F100 May 29th 2014, 12:13 pm
ape550 wrote:valves were set a 1/2 turn past zero lash.  Have already been backed off a 1/4 turn to check that theory.    Sure it has to be a vac. leak somehow.      Will update on tonites findings.
Get the vacuum leak fixed bad vac leak will not let it idle worth a flip but make sure you have the cam broke right before you try idling or you going to be changing the cam again.
Post  ape550 May 29th 2014, 12:25 pm
I'm gonna hook up the smoke machine to the intake tonight. I pray I find a leak!! If it's not I am at a loss. I have double and triple checked everything else. Idled and ran so nice before even with one cylinder down.
ape550
wont idle / help please Empty found it!!!!
Post  ape550 May 29th 2014, 8:54 pm
Well well well. feel like a dummy. don't know how it happened but the vac. port at the bottom rear of the carb was uncapped. I never touched the carb during the cam change. that's why I didn't inspect it closely. live and learn. Idles just like before now.
ape550
Post  Dave C. May 29th 2014, 9:39 pm
 cheers
Dave C.
