78 F150 460 ENG Oil Pan Wont Come Out
78 F150 460 ENG Oil Pan Wont Come Out Empty 78 F150 460 ENG Oil Pan Wont Come Out
Post  BigBoy460 December 22nd 2012, 6:08 pm
I have a 78 ford F150 with a 460 engine and the welded in cross member wont allow the oil pan to come down enough to pull it out anybody have any ideas with out pulling the engine?????
BigBoy460
78 F150 460 ENG Oil Pan Wont Come Out Empty Re: 78 F150 460 ENG Oil Pan Wont Come Out
Post  maverick December 22nd 2012, 7:40 pm
Can you unbolt the engine mounts and lift the engine just enough to pull the pan without disconnecting everything else?
BTW, what's the reason for pulling the pan? ...it might be worth yanking the engine.
Post  BigBoy460 December 22nd 2012, 7:46 pm
There was a small leak and the bolts were hand tight the engine was rebuilt when I bought it a year ago, so when i was inspecting everything this morning I noticed that the bolts were not tight at all and one was missing, I also want to paint the oil pan and seal it back the right way, but I am thinking of pulling the engine so I can put a better piston in not sure yet....
BigBoy460
Post  Frank Merkl December 22nd 2012, 7:48 pm
you'll need to jack the motor as high as you can and put a spacer in the motor mount to hold it there ,ie a 13/16 deep socket laid in the mount works , and you may need to drop the oil pump and pickup in the pan to get it out , I believe that's how I use to do it back in the late '70's when I worked on the bench!
Post  BigBoy460 December 22nd 2012, 8:09 pm
Ok thanks Frank
BigBoy460
Post  cletus66 December 23rd 2012, 11:39 pm
Frank Merkl wrote:you'll need to jack the motor as high as you can and put a spacer in the motor mount to hold it there ,ie a 13/16 deep socket laid in the mount works , and you may need to drop the oil pump and pickup in the pan to get it out , I believe that's how I use to do it back in the late '70's when I worked on the bench!
That's how you get it out. Gettin' it back in though....... Shocked
Post  res0rli9 December 24th 2012, 9:30 am
Yes if you think getting it out is bad, waite till you try and put all 3 back at the same time.
Post  Frank Merkl December 24th 2012, 1:43 pm
Back in the day that's how it was done on the bench , Yes it is tricky to to re-position the pump back in and get the drive rod in place but the pan hangs down about 5" so it isn't to bad
