Splayed cap torque sequence?
How do you torque them down? Main bolts then splayed? or back and forth between main and splayed using equal torque numbers until you reach the splayed bolt number then continue with the mains?
I did a search but didn't find it mentioned in the posts...
Thanks, Casey
Thanks, Casey
8liter- Posts : 202
Re: Splayed cap torque sequence?
8liter wrote:How do you torque them down? Main bolts then splayed? or back and forth between main and splayed using equal torque numbers until you reach the splayed bolt number then continue with the mains?
Thanks, Casey
you do the mains first just as if were a 2 bolt,then the splayed in the same order,starting with the center
BOSS 429- Posts : 2371
thanks...
8liter- Posts : 202
» torque specs for svo block splayed main cap bolts
» Found these new Splayed Main Caps at the PRI show
» what studs/bolts are ya'll using on splayed 4bolt caps?
» Wanted: splayed main caps
» no low end torque
» no low end torque
