no low end torque
no low end torque
Hello I have a question about a stock 1971 429 with dove c heads stock cam ,edelbrock perfomer intake , a new 600 edelbrock carb from a 750 holley dp,70000 mi, good oil pressure clean engine, good compression, good vacuum but absolutley no low end at all could it be in the intake my other 429 exactly the same year an car had much stronger low end torque what could it be any ideas. THANKS
1971tjet- Posts : 18
Re: no low end torque
1971tjet wrote:Hello I have a question about a stock 1971 429 with dove c heads stock cam ,edelbrock perfomer intake , a new 600 edelbrock carb from a 750 holley dp,70000 mi, good oil pressure clean engine, good compression, good vacuum but absolutely no low end at all could it be in the intake my other 429 exactly the same year an car had much stronger low end torque what could it be any ideas. THANKS
Probably, the cam timing is retarded so "degreeing-in" the camshaft would maybe help a bunch.
Check and make sure the dist. is in fact advancing correctly. If not,it will be very sluggish and most likely pop back thru carb under hard acceleration.
how much gear is in the car?
RANCHEROMAC likes this post
its a stock 280 gear but so was the other car and it had stong torque down low , i did replace the advance an its working ,dfree383 wrote:how much gear is in the car?
its geared high 280 but so was the other car an it had alot of torque down low , ? ps im new to this so bare with me thanks
» Would you rather have hp or torque?
» Cam advice needed.
» Head Torque ?
» My brother's "Former" 521.... Dyno Results...........
» lug nut torque
» Head Torque ?
» lug nut torque
