lug nut torque
rck532
lug nut torque
I have the good 5/8 wheel studs on my drag racing ranger
With weld aluma-stars
what should I torque the lug nuts to
thanks Rick
thanks Rick
rck532- BBF CONTRIBUTOR
Re: lug nut torque
We always went 100 ft. pounds.
Nevs- BBF CONTRIBUTOR
Re: lug nut torque
80 - 100 Rick .......
Re: lug nut torque
Used to worry about the torque on the drive studs long ago. Now I just zing them on with an impact & forget it.
I will say that I have seen a few of the Strange sleeved drive studs back off/out of the axle flange over time if you go crazy with the impact when putting the wheels on. But never a problem putting wheels on with an impact on MW drive studs if the drive studs are installed correctly in the axle flange.
DILLIGASDAVE- Posts : 2262
Re: lug nut torque
Lug nuts are usually one of the last things to be done....does that mean the new motor is done???
90-95# for me BTW...
Treeyasoon- Posts : 759
Re: lug nut torque
Treeyasoon wrote:Lug nuts are usually one of the last things to be done....does that mean the new motor is done???
it will be done this week
Re: lug nut torque
always did 100 ftlbs, dont forget the trailer while your at it.................
Re: lug nut torque
Good point and often overlooked until the tire passes you....
Re: lug nut torque
One thing on trailers people don't think about is how close the axles and tires are with the twisting and turning will loosen the lugs over time it a good thing to put on the check list before heading out.90 to 100 on 5/8 but also should check the wheels some wheel companys recomand there own torque to keep from damageing the wheel
» Cam advice needed.
» no low end torque
» torque
» My brother's "Former" 521.... Dyno Results...........
» Torque box
» no low end torque
» torque
» Torque box
