Used cam break in.
Used cam break in. Empty Used cam break in.
Post  Mustang-junky August 11th 2012, 8:24 pm
I have a solid flat tappet cam that I would like to reuse. With all the lifters in their original locations will I still need to remove the inner valve spring for initial start up? I plan on using Comps break in oil. The cam is a Luniti 41607.
http://www.lunatipower.com/CamSpecCard.aspx?partNumber=41607
Thanks.
Jess
Mustang-junky
Mustang-junky
Used cam break in. Empty Re: Used cam break in.
Post  c.evans August 11th 2012, 9:31 pm
If it is in a different block, then you need to treat everything as if it was a new cam break-in.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  Mustang-junky August 11th 2012, 9:47 pm
c.evans wrote:If it is in a different block, then you need to treat everything as if it was a new cam break-in.
Charlie
Ok. The block is different. My machinist said the same thing. I was just looking for a second opinion, as he is not a ford specialist, such as the folks here.
Thanks.
Jess
Mustang-junky
Mustang-junky
