Injected Q16 passes
Barney
KY JELLY
Injected Q16 passes
Made 3 passes on the q last night had the expected tuning issues right now the biggest problem is its not getting up on the converter at the launch . It ran a 21 first pass 14 on a pill change and then a 08 . Its bogging off the line due to not getting up on the converter but it cleans up fast and pulls like crazy .
KY JELLY- Posts : 1530
Re: Injected Q16 passes
You'll get it figured out. Your probly killing .01 to .015 just on the leave. That thing is wicked straight btw.
get it figured out and hang on!
Good looking passes Randy.
61coon- Posts : 1824
Keep on it Ky. udaman
Thanks guys , some of the tuning issues are probabaly self inflicted I am running the fuel pump direct drive off of the drysump pump for room and safety issues in case i lose the belt. This is overdriving the fuel pump a little .
Edit got it lined out . I am slowly learning an egt reading on c heads does not mean squat.
This thing is idling at 360 degrees (egt) and sings that converter to 6600 rpm on the transbrake. I might have feed this thing a little more on the main pill too .
In the first video it looks like it might have dead-hooked for a split second before it got up on the tire (possibly from bogging/not getting up on the converter). But after it got some wheel-speed going it was gone.
In the second video it might have had a little better wheel-speed, but I can't tell for sure because of the later night/darker video.
DILLIGASDAVE- Posts : 2262
» Bt injected tunnel ram with carbs ?
» video mechanical injected q16
» Injected methanol / green oil
» fuel injected 460 questions
» Alcohol Injected Modified 4x4 Puller
