procomp bb
+10
Larry T
Mustang-junky
56Tbird
Race Ready Fabrications
Barney
cesarperez
14 posters
procomp bb  Empty procomp bb
Post  cesarperez August 20th 2012, 7:14 pm
does any one on this forum have flow numbers on the bb procomp ford heads Neutral
cesarperez
procomp bb  Empty Re: procomp bb
Post  richter69 August 20th 2012, 7:21 pm
oh my, its about to get busy up in here......... Razz
Post  Barney August 20th 2012, 7:38 pm
Good lawd that's a cheap set of aluminum racin heads...they can be used for a stock replacement type head. The hardware is Junk, the exhaust port design is suspect at best, they will absolutely cost you more money in the end. If its in a stock type rebuild fine, if your trying to make over 500 -550 hp you will want to look elsewhere.
Barney
Barney
Post  Race Ready Fabrications August 20th 2012, 7:38 pm
cesarperez wrote:does any one on this forum have flow numbers on the bb procomp ford heads Neutral
Please tell me you're not serious!! LOL!!!
Post  John Myrick August 20th 2012, 7:46 pm
You'll be money ahead if you just go ahead and buy a set of Ford SCJA's or SCJB's
Post  56Tbird August 20th 2012, 7:47 pm
Talk to Wes Littrell
56Tbird
56Tbird
Post  Mustang-junky August 20th 2012, 7:50 pm
Mustang-junky
Mustang-junky
Post  Larry T August 20th 2012, 8:18 pm
have you hit the newbie thread yet? Wink
Larry T
Larry T
Post  richter69 August 20th 2012, 8:23 pm
its been so long since we had a good old fashioned pro comp bashin' thread.........I guess everyone figured out how much they sucked lol.
hell of a first post...... cheers
Post  rmcomprandy August 20th 2012, 8:27 pm
I have all kinds of flow numbers on them but, IF you gotta know flow numbers ... these heads are not for you.
The castings are good quality and they have their place however, THEY ARE NOT RACE HEADS.
Post  dfree383 August 20th 2012, 11:05 pm
We have one? lol!
Post  IDT-572 August 20th 2012, 11:11 pm
Don't let the squawking in this post run you off.................. The pro Comp heads are a controversial piece on this board.
Some on some other boards have bought them and made some outlandish claims which are unfounded. The heads are a good for a street car for mild hp (no better than a nice ported set of stock heads) less weight on the front of your vehicle.
The castings are nice they flow a tick under 300 cfm with a bowl blend with out of the box assembled head. But they come with sub standard parts, guides too tight, just a bunch of problems you have to check before installing on the engine. They are best bought bare and built to suit with quality parts and good machine work.
I have ported several and gotten them to around 370 cfm intake and 235 on the exhaust. Swapped out a set of 320 cfm doves on a friends car and it ran the same after tuning. A ton of money spent and no performance gained. (even with 70 lbs lost on the total weight of the car)
Just make sure what you want and need out of a set of aluminum heads before you buy Pro Comps.
JMHO
procomp bb  Empty heads
Post  cesarperez August 20th 2012, 11:26 pm
what is the best bbf head for the money
cesarperez
Post  richter69 August 20th 2012, 11:29 pm
that depends on what your doing.......... Very Happy
Post  IDT-572 August 20th 2012, 11:38 pm
Mid tens at 3000 lb. the best bang would be a set of bowl blended Doves, mid 9's a set of SCJ Motorsport heads would be the economical ticket. ect. Just let us know what you have on your mind.
Post  cesarperez August 21st 2012, 12:19 am
iam a mopar racer and geting into the ford scene i just bought a 1970 comet and want to build a notalgic prostock 4 spd -with a tunnelram 3000 lbs with 12x30 slicks that can get into low nines
cesarperez
Post  IDT-572 August 21st 2012, 12:27 am
cesarperez wrote:iam a mopar racer and geting into the ford scene i just bought a 1970 comet and want to build a notalgic prostock 4 spd -with a tunnelram 3000 lbs with 12x30 slicks that can get into low nines
Your best bet will be a set of SCJ Motorsport heads bowl blended with 14:1 compression and a well matched engine combo.
Low nines will take a fair amount of hp......... 800 min if you are a chassis guru, 850 + if your so so on chassis knowledge,
900 if its your first goat roping.................... Laughing
Post  dfree383 August 21st 2012, 12:34 am
The procomp stuff is not a good choice for your goals.
Like Blake has suggested, the Ford Racing SCJ A or B's (Kasses design) or even a set of Kasse P-51's are a great choice if you have a little more money.
If you looking for a Nostalgic look (IE factory look) the Blue Thunder Ford Exhaust Port heads will look the part. and can be made to perform very good too. The ends of the heads are shaped like factory iron heads.
Post  cesarperez August 21st 2012, 1:01 am
what is better trick flow or blue thunder
cesarperez
Post  dfree383 August 21st 2012, 1:02 am
cesarperez wrote:what is better trick flow or blue thunder
Out of the Box? or modified?
Post  cesarperez August 21st 2012, 1:08 am
stock
cesarperez
Post  dfree383 August 21st 2012, 1:23 am
Thats a damn tough question to answer. They are both good parts.
The BT stuff does offer a BBC Exhaust port and various chamber sizes.
The TFS heads are a little smaller ports and would be a better choice for a smaller motor IMO.
They can both can be very good performers in the right porter's hands when modified.
For me if I was doing a nostalgic PS car and wanted it to close to period correct, I'd use the BT heads. But if your not worried about looking correct I'd be using P-51's or if your a little light on $$$ then the Ford Kaase SCJ's
Post  rmcomprandy August 21st 2012, 10:33 am
For nostalgia Pro Stock ...
As Dave said, if you want the "look" then use the Blue Thunder's with raised CJ exhaust ports; they won't be inexpensive however, if performance is your goal then I personally would use P-51's; no question.
SCJ's from FRPP are probably the best "bang for the buck".
Post  jbozzelle August 21st 2012, 11:41 am
SCJs or the P51s would be the best bang for the buck. I went with the P51s just due to them being "ported as cast" out of the box and not needing any other work. I figure I could run them as is for now and when I step up in cubes I'll send them out to get worked on.
Post  bbf-falcon August 21st 2012, 12:28 pm
Welcome to the Forum. Blake(ITD572),Randy(rmcomprandy),Dave(Dfree), are all really knowledgeable bbf engine/head guys,so listen when they talk,they won't steer you wrong. Lots of info in this thread so far,so thanks for posting.
