nitrous cam ?
nitrous cam ? Empty nitrous cam ?
Post  bruno August 25th 2012, 7:37 am
did some internet reading and found this
http://www.carcraft.com/techarticles/ccrp_0605_nitrous_cam_guide/viewall.html
but was curious has any of you cam guru's heard about 122-125 lsa for big nitrous cams ????? or was that just someone blowing smoke ....... study .........
http://WWW.CKRME.COM
nitrous cam ? Empty Re: nitrous cam ?
Post  dfree383 August 25th 2012, 7:46 am
Please define "Big"......
That artical is a pretty mild motor...
Post  bruno August 25th 2012, 7:51 am
dfree383 wrote:Please define "Big"......
the article doesnt really refer to what i was talking about , just something i read while trying to find the answer , and there was no info about it. using 800-1000 hp worth of nitrous , what kind of cam are these guys using , or is it top secret stuff ? and what is the limit on a 4.600 bore as far as pumping the juice ?
Post  dfree383 August 25th 2012, 8:00 am
Typical the heads used for real NO2 engines are done different than N/A..... If that means anything, But I'm not up on the cam tech used for "Big Boy Hits" But it does make sence using a bigger exhaust lobe and spreading out the LS
Post  richter69 August 25th 2012, 11:12 am
speak with you engine builder, I think he might know a thing or two about nitrous......... and cams for nitrous... Wink
Post  rmcomprandy August 25th 2012, 11:28 am
That article is about using the correct camshaft for taking advantage of nitrous with a relatively mild street engine.
If you KNOW a particular race engine is going to be used with nitrous ALL THE TIME then you can take advantage of a special NITROUS grind.
A few degrees of extra intake duration, a few more degrees of extra exhaust duration and a wider lobe separation than what would normally be used in that combination NA, would be better utilized when using nitrous.
REMEMBER, nitrous is a TORQUE maker.
Post  bruno August 25th 2012, 8:16 pm
richter69 wrote:speak with you engine builder, I think he might know a thing or two about nitrous......... and cams for nitrous... Wink
if everybody spoke with there engine builder there would ne no need for this place Very Happy
i just had several general questions .is there such a cam? , were they blowing smoke?, is there a limit on a 580-600 cu inc as far as filling the cylinder with nitrous ?
Post  schmitty August 25th 2012, 11:05 pm
bruno wrote:, is there a limit on a 580-600 cu inc as far as filling the cylinder with nitrous ?
Load it up till it goes "BOOOM", then back it off a little. Laughing
Post  cool40 August 25th 2012, 11:17 pm
dfree383 wrote:Typical the heads used for real NO2 engines are done different than N/A..... If that means anything, But I'm not up on the cam tech used for "Big Boy Hits" But it does make sence using a bigger exhaust lobe and spreading out the LS
^^^this.........the cam profile has everything to do with it but your heads can be a very big plus for "man shots". Wink
