Ring gap info
Ring gap info
Would anybody here be able to to tell me what the ring end gap should be for some rings?
They are some Sealed Power ZE296K.
http://www.summitracing.com/parts/SLP-E-296K/
I wanted to double check to be sure I have them right, but cant find the paper that came with the rings.
OldRedFord- Posts : 465
Re: Ring gap info
Somewhere around .017 0n top and .019 on 2nd. if it's NA. W/O looking it up. Thats w/ring square and 1" down in the cylinder.
Re: Ring gap info
bbf-falcon wrote:Somewhere around .017 0n top and .019 on 2nd. if it's NA. W/O looking it up.
Thanks man.
Re: Ring gap info
I would say it depends on your performance level... I do all of my performance stuff at .024-.028 for the top ring, and .028-.032 for the second ring...
Doug...
Doug...
ThndrChkn- Posts : 2216
Re: Ring gap info
1bad521 wrote:I would say it depends on your performance level... I do all of my performance stuff at .024-.028 for the top ring, and .028-.032 for the second ring...
Doug...
man im glad to here that, local performance shop told me i went to far with .026 top n .028 on second, i told him i was puttin on a 150 shot he said its still to much, but he`s a bbc guy thanks for the info.
hillbillyerv- BBF CONTRIBUTOR
Re: Ring gap info
It depends what bore you have. My reply was for a 4.360 (Stock) bore.
Re: Ring gap info
Not stepping on toes here, but this is my routine...
I just follow a basic rule of thumb taught to me years ago when I was still a teenager...
For standard N/A apps. I use .004 per inch of bore for the top ring and .005 for every inch of bore for the 2nd ring...
For N/A HP street stuff, I use .005 per inch of bore for the top ring and .006 for every inch of bore for the 2nd ring...
For N/A engines like my 521, I use .0065 per inch of bore for the top ring and .0075 for every inch of bore for the 2nd ring... However, there's a guy here that will add another 10% to this particular figure if it's a higher rpm deal... He says it helps improve ring seal and allows the gases to escape before blowing by the top ring causing ring flutter in the higher rpm ranges... (Above 6000-6500) I haven't noticed evidence of this in my engine as of yet and I shift it at 7200 and it's been to 7700 a few times...
If I was doing a N2O/Supercharged engine, I would open each up another .0005 per inch of bore...
And regardless of app, I always make sure the oil rings are about .015...
Hope this helps,
Doug...
Hope this helps,
Doug...
Re: Ring gap info
I like Dougs advice in his last post. But seeing this is basically a freshened up stocker with a small cam, I think I will go with what BBf-Falcon posted. But farther on down the road Ill use Dougs rule of thumb.
Re: Ring gap info
Tim, I think we all agree that the main thing to remember is it's always better to have plenty of clearance than not enough. Good Luck Buddy
Re: Ring gap info
I have .018 on the top ring, and .020 on the bottom.
Re: Ring gap info
Your good to go
» piston ring choice and preferred ring seat/breakin time ?
» Do they make a ductile Iron ring 5/64 X 4.39 bore or whats a good ring?
» ring gap for n0s
» Ring Gap
» Filing rings
» ring gap for n0s
» Ring Gap
» Filing rings
