Timing Chain/Sprocket
1faststang
Just wondering what would be the best bang for the buck Timing Chain/Sprocket to use in a build making around 750HP?.
1faststang- Posts : 129
Re: Timing Chain/Sprocket
Ford Racing. Get w/Lem. He will give you a great deal.
bbf-falcon wrote:Ford Racing. Get w/Lem. He will give you a great deal.
Thanks!.. I was thinking of the Ford M-6268-A460 set
Lem's got the hookup, get a bronze thrust plate while your there.
richter69 wrote:Lem's got the hookup, get a bronze thrust plate while your there.
Thanks!!..The Bronze Thrust Plate is much better?.
Just read up on the Bronze Thrust Plates.. Glad you told the rookie about them.. Thanks!!
The bronze plate works better that the iron plate when using a steel cam and steel cam gear.
Lem Evans wrote:The bronze plate works better that the iron plate when using a steel cam and steel cam gear.
Thanks again Lem
Harold,if you are reading this,you need one when you change your cam timing.
I've been away for a while and maybe things have changed some....... but I recall 'double pinning' being a recommended BBF build step some time ago.Lem Evans wrote:The bronze plate works better that the iron plate when using a steel cam and steel cam gear.
What is the latest thinking on getting the cam & gear drilled for a double dowel pin?
StickBBF
StickBBF- Posts : 27
You need to do it and also upgrade to a .4375 retaining bolt is a good addition.
» Advance Cam or Not ?
» Timing chain question...
» Timing chain
» Timing chain and oil pan questions
» Timing chain help
» Timing chain
» Timing chain help
