SBF valve lash (mechanical cam)
+8
ustahava67
LivermoreDave
514Fox87
Larry Williams
bb429power
12 posters
SBF valve lash (mechanical cam) Empty SBF valve lash (mechanical cam)
Post  bb429power September 21st 2012, 8:22 pm
I have a mechanical flat tappet cam and need to be able to adjust the valve lash properly. The heads have factory rocker arms that are tightened down with bolts like a pedestal mount. I'm wondering if there is a way to adjust the valve lash with these because with the mechanical cam its supposed to be set at .022"
Any help would be appreciated
bb429power
bb429power
SBF valve lash (mechanical cam) Empty Re: SBF valve lash (mechanical cam)
Post  Larry Williams September 21st 2012, 8:41 pm
you need to install a rocker stud that allows for the adjustment of the proper clearance. If I remember right I used to use chevy screw-in rocker studs. It will mean you will have to buy rockers too. I think you may have to machine the boss on the heads about the thickness of the hex part of the stud. Then thread the holes to accept the studs
Larry Williams
Larry Williams
Post  bb429power September 21st 2012, 10:04 pm
The holes are already threaded, and I do have a set of heads that are all assembled with pressed in studs and rocker arms. I'm not sure if I can use those somehow. But I also have a set of bbf harland sharps, and bbf head studs. Not sure if I can make something up that will work with the parts I have laying around. Neutral
bb429power
bb429power
Post  514Fox87 September 21st 2012, 10:06 pm
JEGS Performance Products 20185
Ford Pedestal Rocker Shim Kit
(16) 0.030"
(16) 0.060"
Item# 555-20185
Ships Today
Only $8.99
More Info
514Fox87
514Fox87
Post  bb429power September 21st 2012, 10:11 pm
(16) 0.030"
(16) 0.060"
Item# 555-20185
Ships Today
Only $8.99
More Info
What do I do, put them between the rocker arm and cylinder head? And another question, would I be able to obtain the .022 lash I need with those? (I'm wondering because it says .030 and .060)
bb429power
bb429power
Post  Doug Rahn September 22nd 2012, 4:19 am
Harland Sharp has a set of adjustable pedestal mount rockers, but you limited on spring pressure. I have a set on my small block Mustang.
http://www.harlandsharp.com/ford_v6_v8.htm
Post  bbf-falcon September 22nd 2012, 8:29 am
bb429power wrote:The holes are already threaded, and I do have a set of heads that are all assembled with pressed in studs and rocker arms. I'm not sure if I can use those somehow. But I also have a set of bbf harland sharps, and bbf head studs. Not sure if I can make something up that will work with the parts I have laying around. Neutral
It's been a few years since i've worked w/small blocks alot,but the BBF rockers will be the wrong ratio for the SB. The studs will probably be too long also.
Post  LivermoreDave September 22nd 2012, 9:06 am
IMO, I would buy a hydraulic design flat tappet camshaft suitable for your application. The route your trying to travel might bring you a bit of bad luck.
Dave.
LivermoreDave
Post  bb429power September 22nd 2012, 9:19 am
Already have the cam, and this will be a strip only car. And I know I'll have to check the valve lash often. And those harland sharps are useless to me then, I may sell them. They never got used on the big block.
I'll look over my setup again today and check out the mounting a little better
bb429power
bb429power
Post  bb429power September 22nd 2012, 10:06 am
Would that shim kit allow me to set it at .022 lash or should I buy a set of .020 shims from elsewhere? I'm about to order some parts
bb429power
bb429power
Post  dfree383 September 22nd 2012, 11:38 am
bb429power wrote:Would that shim kit allow me to set it at .022 lash or should I buy a set of .020 shims from elsewhere? I'm about to order some parts
You need to install adjustable rockers, either the Harlin sharp ones that bolt on or have the heads machines for studs, guide plates and get hardened pushrods.
The shim thing is asking for failure.
Post  ustahava67 September 22nd 2012, 12:00 pm
The Shim kit is for setting lifter preload on a hydraulic cam/pedistal mount rocker set-up.It will not work for setting lash with precision that you will need for a solid cam. The right way to do this is to have .200 milled off the rocker pedistals, have the rocker mount holes drilled and tapped to 7/16-14, and install srcew-in studs, guide plates and hardened pushrods. It would be cheaper and easier to just put in a hydraulic cam. Unless the heads you are working with are something special, a set of pedistal mount iron SBF heads aren't worth what it would cost in machine work to convert them to studs
ustahava67
ustahava67
Post  bb429power September 22nd 2012, 12:24 pm
Well i have the cam already minus the lifters. I wanted a mechanical cam so the higher rpms wouldn't be an issue like the hydraulic might have with bleeding off. As far as machining for studs, the holes are tapped and the cost of machining them, getting studs guidplates and rockers for a stud setup would be more. I'm not sure what to do now, I cant get a different cam, and I'm not sure what I'm going to do at this point.
bb429power
bb429power
Post  Diggindeeper September 22nd 2012, 12:28 pm
Should have bought those Windsor jr heads, they come with all that. Very Happy
Diggindeeper
Diggindeeper
Post  bb429power September 22nd 2012, 12:32 pm
Diggindeeper wrote:Should have bought those Windsor jr heads, they come with all that. Very Happy
Still wouldn't be able to buy them. $$$
bb429power
bb429power
Post  bb429power September 22nd 2012, 12:44 pm
I saw these but they are probably junk
http://store.440source.com/Rocker-Shaft-Shims-pkg-of-30/productinfo/127-1020/
bb429power
bb429power
Post  bb429power September 22nd 2012, 12:54 pm
Edit- nevermind
bb429power
bb429power
Post  bb429power September 22nd 2012, 6:58 pm
Looking at my options as far as roller rockers... if anyone has a set let me know please
(have some bbf harland shaps 1.73 brand new if interested in a trade)
bb429power
bb429power
Post  dfree383 September 22nd 2012, 10:53 pm
bb429power wrote:Well i have the cam already minus the lifters. I wanted a mechanical cam so the higher rpms wouldn't be an issue like the hydraulic might have with bleeding off. As far as machining for studs, the holes are tapped and the cost of machining them, getting studs guidplates and rockers for a stud setup would be more. I'm not sure what to do now, I cant get a different cam, and I'm not sure what I'm going to do at this point.
The hydraulic cam is going to be the cheapest way that will work properly.
Post  bb429power September 22nd 2012, 10:55 pm
Hydraulic cam isn't really an option to us right now. I'll have to make it work somehow
bb429power
bb429power
Post  powerstrokeace September 22nd 2012, 11:38 pm
What year are the heads? if I'm thinking right your going to have to remove the heads and mill like .300 off the pedestal before you can put any screw in studs. and your going to need to put in a larger diameter like from 5/16 to minimum 3/8. then you can get new roller rocker arms and you may still need to get custom push rods. This is all out lined in the FORD racing catalogs
Ace
powerstrokeace
powerstrokeace
Post  bb429power September 22nd 2012, 11:43 pm
I wonder if I can shim it up .020" to get by for now, then get fully adjustable rocker arms. But I don't know, can't figure out what I'm going to do now Mad
bb429power
bb429power
Post  bb429power September 22nd 2012, 11:44 pm
And these are 97 GT-40P heads, which are commonly used
bb429power
bb429power
Post  dfree383 September 23rd 2012, 9:50 am
bb429power wrote:I wonder if I can shim it up .020" to get by for now, then get fully adjustable rocker arms. But I don't know, can't figure out what I'm going to do now Mad
No you can not get by like that.... Either do it right or stop asking! Rolling Eyes
You can get a decent performance hyd cam and lifters for under $200, or even less If a no name cam will suffice. Summer sells a few grinds for under $120, Typically with the right grind and decent springs they will go to 6800 +/- sometimes a little more.
http://www.summitracing.com/parts/SUM-K3602/
http://www.summitracing.com/parts/CCA-CL31-246-3/
Studs, guide plates, rockers, pushrods and machine work are going to set you back about in the $500-800 range depending on the quality of parts desired.
Post  bb429power September 23rd 2012, 10:48 am
Let me give a little background info on what it had in it, a set of stock 68 302 heads with valve springs and that's it. Then the cam was an edelbrock performer rpm and I took that thing to 7200 if I revved it in neutral, shifted at 6500 with ease.
http://www.summitracing.com/parts/EDL-7122/
Now what I'm trying to do which wont work is use a set of GT-40P heads that I ported and am putting springs on. And use the bigger cam that I got from Lunati. I can't find a link to it but its definitely an upgrade. Now either I buy a set of roller rockers with a pedestal mount for $175 and use this cam, (which I'm guessing would require guideplates and maybe pushrods?)
Or I buy a new cam and lifter kit for $200 and use my stock stamped steel rocker arms.
Sound about right?
bb429power
bb429power
