429 - valve lash setup
429 - valve lash setup Empty 429 - valve lash setup
Post  Mestro March 14th 2015, 6:17 am
Hi there,at my 429 code n engine it seems that the valve lash is not setup properly.
Attached you can find a pic of the rocker in the folowing dropbox. The engine has hydraulic lifter.
https://www.dropbox.com/s/y7s13k5071aoeri/2015-03-14%2010.58.45.jpg?dl=0
Can you please help me how to setup the valve lash?
Many thanks in advance
Best regards from Germany
Marco
Mestro
429 - valve lash setup Empty Re: 429 - valve lash setup
Post  maverick March 14th 2015, 9:13 am
With hydraulic lifters there will be no lash (clearance).  You'll need a bit of preload on the lifters.  On your stock 429, the simplest method would be:
Remove the spark plugs.
Following the firing order (15426378) bring each cylinder to top dead center on the compression stroke.  On each cylinder, that will be at TDC after the intake valve closes.  The cylinders are numbered 1234 on the right bank, 5678 on the left bank.  Be sure that you're turning the engine in its normal direction of rotation.  Once you have #1 at TDC, you'll simply rotate the crankshaft 90 degrees to bring the next cylinder in the firing order to TDC.
With the piston at TDC, loosen the rocker nut (both intake and exhaust) until you feel slack or clearance.  Then slowly tighten the nut just until clearance is gone, then tighten another 1/2 turn to preload the lifter.  That'll get you close enough for the girls I run with. Wink
What car is your 429 in?
Post  Mestro March 14th 2015, 9:51 am
Hi there,
Many thanks for your help.
The car is a 1970 Ford Torino GT and 4speed toploader. Car has been in Germany since 2012.
Best regards
Marco
Mestro
Post  maverick March 14th 2015, 9:56 am
I love the '70 Torino. If I had a time machine, I'd take a big stroker in a '70 Torino Cobra back to 1970. The guys I ran with would pee themselves. Cheers to you.
429 - valve lash setup Empty valve setup
Post  gas6999 March 20th 2015, 7:25 am
I still do the hyd, just like solid,, exh, starts to open the I set the int, take slop out of push rod and turn the adj, nut another 1 turn, then when the intake comes up and just starts to go back down adj, the ex, that will make sure your on the lobe heel of the cam.
gas6999
