Valve lash
Valve lash
I have a custom ground cam that came in engine & do not no the specs. I used it in my new engine build because of the tough times. It is a solid flat tappet cam & I was wondering what I should set the valve lash at. I have it set at .020 right now & it seems to run fine.
mustangjeff- Posts : 87
Re: Valve lash
If .020" works by all means use it There should be some numbers on the face of the front or rear journal that would tell you what you have .
Re: Valve lash
I searched the numbers that were stamped on the back of the cam & could find no information on the cam, I guess I should of asked you guys.
» Valve lash
» SBF valve lash (mechanical cam)
» valve lash question
» how often should you be adjusting valve lash?
» 429 - valve lash setup
