Red 1984 Thunderbird with 466ci Big Block Ford (Ohio)
56Tbird
Gary Varney
- 84 Thunderbird
- 466ci Big Block Ford
- Wiseco Flat Top Pistons
- Flat Tappat Cam
- Roller Rockers
- Cobra Jet Aluminum Heads, Ported, Stainless Valves
- Wieand Aluminum Water Pump
- Moroso Water Pump Drive
- Mallory Unilite Distributor
- Ford Racing Valve Covers
- Proform center 750 Carb
- SFI Balencer
- Coated Headers
- Aluminum Radiator
- JW the Wheel Flexplate
- JW Ultrabell
- Powerglide with Brake
- TCI 8" Converter
- Pro Ratchet Shifter
- Shiftnoid Electric Shift Activator
- Deadenbear Crossover Delay Box
- 9" Rear - Braced
- Strange Center Section
- .456 Gear
- 31 Spline Moser Axles
- Spool
- 4 Wheel Disc Brakes
- Wheel Tubs
- 31x14 Rear Tires
- Weld Wheels
- Leaf Spring Rear Suspension
- 6 point Roll Bar
- 2 Batteries
- MSD 6AL
- All Lexan Windows
Car has gone 10.48 at 129mph with mild tune-up. Engine and Trans have less then 80 runs, Body Very nice, even door jambs still look new. Very pretty low matience car.
Turn Key. Located in Etna Ohio. (Eastern Central Ohio)
$9,300
Call Gary: 614-323-5259
Gary Varney- Posts : 102
Re: Red 1984 Thunderbird with 466ci Big Block Ford (Ohio)
Thats a nice car Gary. Its a shame Ashley doesn't race it anymore. Good luck brother.
Thanks Rick, she has a baby now and just not enough time. She had a blast with it and went a lot of rounds. I remember one time I had the car at the track for her because she had to work late, she got there right at 1st round and dialed it in with no time runs and ran dead on with a 2. Better than the old man does!
That's a hell of a deal for somebody. Gary's stuff is top notch! Good luck Gary.
56Tbird- BBF CONTRIBUTOR
So many good deals...so little money
GT300TD- BBF CONTRIBUTOR
Leaf springs???
droppedf100- Posts : 176
droppedf100 wrote:Leaf springs???
He has that listed as Leaf springs.
thats a bad ass ride bro
bosshossstanley- Posts : 2
» 466ci Ford Engine with TF Heads - Still Available!
» 466ci Ford Engine with Trick Flow Heads
» 1988 Ford Thunderbird Trubo Coupe pro Street
» 86 T Bird -Sold
» 1987 Ford Thunderbird with 460
» 86 T Bird -Sold
