nitrous and comprresion ratio?
Larry T
65 farm truck
nitrous and comprresion ratio? Empty nitrous and comprresion ratio?
Post  65 farm truck September 25th 2012, 6:01 pm
does it matter how much CR you have for nitrous motor. Is more better 15 or 16 to 1 or would less be better 11 12? any thoughts?
65 farm truck
nitrous and comprresion ratio? Empty Re: nitrous and comprresion ratio?
Post  Larry T September 25th 2012, 7:32 pm
imo it is better to not be over 11.5cr anything above that the tune ups get harder on parts Wink
Larry T
Larry T
Post  65 farm truck September 25th 2012, 9:10 pm
thanks Larry , I am at 15-1 now. My set up is a 598 A460 heads ported by Charlie Evans, Lem custom cam 1250 quick fuel. I leave the line on 300 shot and then bring in 225 more at .5 sec out. all this in a 65 F-100 at 3460# with a power glide and 430 gears. best pass so far has been 5.28 @ 132. I run a heads up class. twice now at 50 to 60 passes it has has developed a head gasket leak. I am trying to solve this and not sure where to start. Cometic gaskets
65 farm truck
Post  richter69 September 25th 2012, 9:14 pm
what fuel?
and Id think thats a good bit of compression........
Post  65 farm truck September 25th 2012, 9:17 pm
c-16
65 farm truck
Post  richter69 September 25th 2012, 9:20 pm
you might switch to C23
Post  richter69 September 25th 2012, 9:21 pm
also are these the 10 or 18 bolt heads?
Post  65 farm truck September 25th 2012, 9:26 pm
they are the 10 bolt, the first leak was between 2 and 3 cyl, this time I dont know , i have not pulled it yet. what will c-23 do?"
65 farm truck
Post  richter69 September 25th 2012, 9:29 pm
Its a better fuel made for nos and multiple systems, more octane etc.
Post  65 farm truck September 25th 2012, 9:35 pm
do you think decreasing the CR will effect HP? I am assuming it will decrease cylinder preasure.
65 farm truck
Post  richter69 September 25th 2012, 10:48 pm
we need pics and video of said vehicle....... Very Happy
Post  cool40 September 25th 2012, 11:25 pm
65 farm truck wrote:do you think decreasing the CR will effect HP? I am assuming it will decrease cylinder preasure.
less cylinder psi could be a good thing.a little thicker gasket would be easy to try.
Post  yellowhorse7 September 26th 2012, 5:05 pm
15:1. DOVE head......I spray it pretty hard. Q16
yellowhorse7
yellowhorse7
Post  richter69 September 26th 2012, 5:45 pm
lol ^^^^^ and how many head gaskets you been through????? Laughing
Post  yellowhorse7 September 26th 2012, 7:47 pm
richter69 wrote:lol ^^^^^ and how many head gaskets you been through????? Laughing
You shush, lol
yellowhorse7
yellowhorse7
Post  bruno September 26th 2012, 8:48 pm
not a nitrous guru but i did stay at a holiday inn .......... Very Happy
how big is the dome ? if any ? I would say the motor would definitely be better off on spray with the compression about 1.5 to 2 points lower. This will cut the dome down and give a better flame front path in the chamber, making the motor more efficient on the hose, as well as easier to tune.......if there is some sort of dome in this deal
also i would think the cam would have more input and where it was installed then the compression ....for a better tunning window
jm .02
http://WWW.CKRME.COM
Post  bruno September 26th 2012, 8:50 pm
have you had any chamber softing done ?
Post  65 farm truck September 26th 2012, 9:45 pm
the heads were ported by Charlie Evans, I dont know what chamber softing is. I will post some picks and video when one of my Sons come over and show me how LOL I talked with Diamond pistons tech dept. today and they siggested lowering CR to about 13 to 13.5. thank yall for the input also!
65 farm truck
Post  droppedf100 April 21st 2013, 10:32 pm
So how about those pics? Sounds like a stout ass old truck. I'm assuming it has some chassis upgrades to be deep into the 5s lol.
droppedf100
droppedf100
Post  Barney April 22nd 2013, 1:01 am
C23 will help a lot. I switched last year and the tuning window got much larger. 600 inch ahead around 16/1. The reality is if your getting 50-60 passes out of a set with that cr, 10 bolt heads, and that much spray your doing pretty good and the 23 with more octane and better sg will help more.
Barney
Barney
Post  droppedf100 April 22nd 2013, 7:22 am
I think the op is gone. He hasn't posted in 8 months and not logged in since November. Sucks I'd love to see this truck. 5.20s is fast in anything let alone a full size truck.
droppedf100
droppedf100
