PA Racing / Strange brakes problem.
Anybody here using the drop spindles from PA Racing with Strange brakes? If so, which part number is your Strange brake kit? I think my brake kit is the wrong one. The caliper brackets don't line up with the holes in the spindle.
jbozzelle- Posts : 3705
Re: PA Racing / Strange brakes problem.
I believe their are two different brake set-ups, 79 to 86 and 87 and up on v8 cars
My brake kit is for 87-93 4 cylinder. I think I need the V8 kit. It's a different part number. I've also got a call into PA.
jbozzelle wrote:My brake kit is for 87-93 4 cylinder. I think I need the V8 kit. It's a different part number. I've also got a call into PA.
I believe the 87 and up 4 cylinder stuff is the same as the V8 stuff from 79 to 86.
I heard from Jason at PA yesterday. I have the wrong brake kit. I got the correct caliper brackets ordered from Strange. The spindle is the same bu tthe spacing on the caliper mounts are different.
» Strange Engineering Front Struts/brakes
» Which lightweight brakes, strange or wilwood? Is there much difference?
» Brakes and bolt pattern problem
» Problem with car racing
» adjusting Front drum brakes
