408/418W build... what would you build?
+10
Fist_Full_Of_Dollars
Larry Williams
14 posters
408/418W build... what would you build? Empty 408/418W build... what would you build?
Post  jbozzelle October 21st 2012, 4:04 pm
My brother is looking to plan out a new build for his Mustang. looking to build between 393-418 inches. Pump gas. Would like a forged crank, h-beams, etc... I've been out of the SBF stuff for awhile. I'm not sure what is out there for heads today. What heads would you guys use and why? AFR? Canfield? TFS High Ports?
408/418W build... what would you build? Empty Re: 408/418W build... what would you build?
Post  Larry Williams October 21st 2012, 4:37 pm
my first small block was a 393 with afr 225 heads went 9.60's I was very happy with it
Larry Williams
Larry Williams
Post  whatbumper October 21st 2012, 5:27 pm
Either 408 or 418 if you stick with small bore. I have a set of bare tfs-r heads if interested.
Post  rmcomprandy October 21st 2012, 5:49 pm
jbozzelle wrote:My brother is looking to plan out a new build for his Mustang. looking to build between 393-418 inches. Pump gas. Would like a forged crank, h-beams, etc... I've been out of the SBF stuff for awhile. I'm not sure what is out there for heads today. What heads would you guys use and why? AFR? Canfield? TFS High Ports?
Build A Big Block ...
Post  richter69 October 21st 2012, 6:09 pm
nothin wrong with a good sbf........
Post  the Coug October 21st 2012, 6:11 pm
Jon I have been gathering stuff for a stout 393 for another project..... maybe next year I will be able to run one or the other....
Post  richter69 October 21st 2012, 6:18 pm
our smallblock car has a plate on it now, should be ready for testing in a week........ Wink
Post  Fist_Full_Of_Dollars October 21st 2012, 6:42 pm
Not that my opinion counts much, but being you say pump gas I would opt for the bigger cubes. What about the CHI heads ? I would think that would make some good power. Are you going to spray it, go N/A or put a hair dryer on it?
http://www.yellowbullet.com
Post  bruno October 21st 2012, 6:51 pm
Laughing Laughing stop your crying !!!!!
http://WWW.CKRME.COM
Post  Fist_Full_Of_Dollars October 21st 2012, 7:11 pm
bruno wrote:Laughing Laughing stop your crying !!!!!
Quit it. I'm trying to mind my manners. Laughing
Post  jbozzelle October 21st 2012, 9:15 pm
If it gets any kind of power added at all it'll be a plate system. Never thought about the CHI stuff. I was kind of wanting to keep it fairly simple for him. Mostly off the shelf stuff to get it built and running in a fairly short time.
Larry, what kind of compression did you have? Any work done to the AFRs or were they out the box? We'll probably run a Super Victor on it. It'll be a 1-2000 mile/year street car and spend some nights at the track every month. Needs to be pump gas though for when he cruises it though.
And Randy I've tried. He wants a SBF.
Justin, what's been done to those TFS heads you have?
Post  Larry Williams October 21st 2012, 9:17 pm
they were out of the box 225's with about 15:00 to 1
2" headers with a super victor and a 950 QFT on alky
gas is only for washing parts isn't it?
Larry Williams
Larry Williams
Post  BOSS 429 October 21st 2012, 10:17 pm
Let me know,I have some 408 stuff sitting, pump gas
Post  whatbumper October 21st 2012, 10:24 pm
My heads are cnc ported from tea. We also welded up and had machined around the stud holes where we had troubles before on the older castings. They are ready for valves and springs. We kept them as extras but now are going to victor sr's for more flow.
Our current sbf with 9.5:1 cr makes over 650 with the same porting program with the motor setup for turbos. You can buy the same ported heads everyday from tea for $1000 each bare.
Post  dfree383 October 21st 2012, 10:46 pm
What's the budget and how fast does he want to go?
Stock block or aftermarket?
Post  jbozzelle October 22nd 2012, 4:01 pm
Stock block, hence the pump gas requirement... As fast at it will allow. Not looking for anything exotic. Was thinking about a set of AFR 205s, flat tops, 408 cubes. He wants to be able to drive it the 10 or so miles to the local cruise nights. Other than that we'll trailer it to the track.
Post  whitefield October 22nd 2012, 4:28 pm
jbozzelle wrote:Stock block, hence the pump gas requirement... As fast at it will allow. Not looking for anything exotic. Was thinking about a set of AFR 205s, flat tops, 408 cubes. He wants to be able to drive it the 10 or so miles to the local cruise nights. Other than that we'll trailer it to the track.
Pistons with a small dish and valve reliefs should be around 10.5:1 with 58cc 205 AFRs. A custom hyd or solid roller cam Vic. Jr intake 950 or 1050 cfm carb running 408 or 418 on 93 0r E85. That should get him 6:70 to 6.50 or faster in the 1/8th running 3.73 or 4.11 gears with 28" tall tires in a 3000lbs to 3200lbs car. I suggest running a c-4 or good easy shifting 5spd with a good clutch. This is a verry streetable set up! good luck !
Flat tops will be around 12.1:1 or better with 58cc heads.
whitefield
whitefield
Post  whatbumper October 22nd 2012, 4:30 pm
i still would put a glide in it. wouldnt cost much and you would never have to worry about it.
Post  whitefield October 22nd 2012, 4:37 pm
whatbumper wrote:i still would put a glide in it. wouldnt cost much and you would never have to worry about it.
I run a c-4 with a lot of passes on it and street miles to with no isssuses ! it runs consistant 6.90s and 7.00s 1.45 60s on drag radials. Thats not to mention 3rd gear burn outs and beating on it around the back roads with the accasional 35 mile trip one way to work.
whitefield
whitefield
Post  jbozzelle October 23rd 2012, 11:25 am
Already have a C4 and a set of 4.10s. Have to start scrounging around for some heads and build from there...
Post  dfree383 October 23rd 2012, 12:02 pm
Call Lem and see what a set of Z304's are going for, they work pretty damn good.
Post  jbozzelle October 23rd 2012, 12:04 pm
What heads did you sell to my dad?
Post  dfree383 October 23rd 2012, 2:56 pm
jbozzelle wrote:What heads did you sell to my dad?
GT40's the z304's are a bigger head more race oriented.
Post  whitefield October 23rd 2012, 3:07 pm
dfree383 wrote:Call Lem and see what a set of Z304's are going for, they work pretty damn good.
If you run the Z304's ask about the rocker arms ? I was thinking they take a different style rocker arm !( Offset)
whitefield
whitefield
Post  dfree383 October 23rd 2012, 3:11 pm
Regular one work fine, I ran a set for 5 years and have another set one the shelf in been playing with. With 2.02 intake and a street valve job they are blowing well over 320 and the mid lift flow is bad ass.
The exhaust was getting 230 with a 1.6
