Another C-head?
+6
Wheelie58
badcoupe
10 posters
Another C-head?
Are there several different styles of these heads? Early model? Late model and if so w
hich one is better
hich one is better
badcoupe- Posts : 112
Re: Another C-head?
C460's are the same to start as the ports are rough cast
Frank Merkl- Posts : 1524
Re: Another C-head?
well my new engine guys head porter said there is an early c head and there not worth using
Re: Another C-head?
badcoupe wrote:well my new engine guys head porter said there is an early c head and there not worth using
Well if he's your head porter guy, believe him. He must be pretty smart. I've CNC ported 53 sets of them and I didn't know that.
Charlie Evans
P.S. If he finds any more of those early C-460 heads that are not worth using,,, I'll take them for the price of scrap aluminum and pay shipping on them, if he'll send them my way.
c.evans- BBF VENDOR SPONSOR
Re: Another C-head?
I understand Charlie and told him he's full of shit but you know engine guys and he's also an engineer so he's never wrong .....pm sent charlie
Re: Another C-head?
Curt- Posts : 2791
Re: Another C-head?
Gerry,he might be mistaking the C head w/one of the other older heads. Charlie knows them all as good as anyone. If I have any head ?'s ,I always call him.
Re: Another C-head?
Ya rick I know something he said about there being a new and old casting like the A heads
Re: Another C-head?
I bet Charlie has been prepping C,A,E,BT,CJ,D0,and more, since Lem was a boy.
Y'all better listen....
Re: Another C-head?
badcoupe wrote:Are there several different styles of these heads? Early model? Late model and if so w
hich one is better
There was something going on.
The 1st C460 engine I did had WW rockers....the intake rocker tip was very much off front to rear. I expressed my consern......WW person said I had the right stuff.
Two years later I needed some replacement parts....the person that answered the phone said.....your the guy that has the wrong stuff....WW sent me the correct stuff that hit the valve correctly .
The new stuff landed on the tip of the valve ~ correctly.
Bottom line is...there is some early stuff that has the intake valve closer to the cyl. wall.
Re: Another C-head?
Wheelie58 wrote:I bet Charlie has been prepping C,A,E,BT,CJ,D0,and more, since Lem was a boy.
No, I really haven't. I just got really tired of doing cast iron Buick Stg 1 heads and always getting my eyeballs drilled to get the metal out. I don't have nearly that amount of trouble with aluminum heads. It's due to the smaller size of the chips between cast iron and aluminum.
The BB Fords make so much more power and Lem is the one who really introduced me to them. I've only been doing them since the late 1990's.
From time to time we do have core shift problems with the C-460 heads, (afterall they are castings) however, I can't blame that on either early heads or late heads. They did more a valve guide centerline over several thou., it was the exhaust I believe, and that was very early stuff. That doesn't make the heads "not worth using" though.
Charlie
Re: Another C-head?
c.evans wrote:Wheelie58 wrote:I bet Charlie has been prepping C,A,E,BT,CJ,D0,and more, since Lem was a boy.
Charlie
"only since the late 1990s..."
If only I had that experience......
You guys make me laugh my ass off...
The Gurus....
Us Hillbillies in GA are sippin' clear liquid and scratchin' our heads....
Some day, I will figure out the KY magic. I gotta...since I am officially 1/2 Kentuckian
Keith
Re: Another C-head?
only half! i dare ask what the other half is.........Wheelie58 wrote:c.evans wrote:Wheelie58 wrote:I bet Charlie has been prepping C,A,E,BT,CJ,D0,and more, since Lem was a boy.
Charlie
The Gurus....
Keith
Re: Another C-head?
Oh Lord, the fact that she married a Yankee is sinful.
Charlie
Charlie
Re: Another C-head?
c.evans wrote: They did more a valve guide centerline over several thou., it was the exhaust I believe, and that was very early stuff.
Charlie
Yes it was moved over .030" towards the intake becuase of guide failure causing the valve to hit the cylinder wall on smaller bores or so the story goes. I wonder if he actually has a set of D heads with the Pro stock block bolt pattern? Since the only difference on an early C/D head is the head bolt pattern it is drilled for he may be thinking it is a goofed up C head
466cj- Posts : 391
C-460
The first C & D-460's had the exhaust + .030 away from the intake valve. They also had a problem with exhaust guide failure because the guide had a taper and would crack. If you have these just install a PPC blunt nose nickle bronze guide. You can also get a larger intake valve in these early heads.
Wilfred has stands for the early and late exhaust valve placement.
Gary Blair- Posts : 221
» Biggest intake seat insert a Dove head will accept, trying to save head from dropped valve.
» Will Jesel Rockers From A Yates Head Work On A C-460 Cylinder head?
» coolant leak between head and block at head bolt location.
» Which Head?- 598 NA
» P51 Head HP gain after head port
